- 21 Apr 2007
I made a thread previously I had been offered what wasn't really that great of a job fit (programming role, e-learning course dev but i've taught myself web dev), but I ended up accepting the offer and got sent the emoployment contract and i've got some questions for some of you that work in tech.
First off i'm typically used to 37.5 hours a week 9-5. This role the contract is instead 9-6 (Not entirely happy with that i'll explain). I'm looking to go back to uni and do part time learning for a masters degree in computer science, ideally an extra hour per day to do studying can add up to quite a lot in the long term. I assumed the role was a typical 9-5 but it isn't, any of you in tech / IT how common is this type of shift pattern is?
The other part of the contract is this:
"The employee shall not be entitled to overtime for working in excess of 40hours a week.".
Can anyone shed light on what that means? it may just be a formality and I won't be asked to do overtime, but if I am then that means it would effectively be unpaid correct?
"The employee's normal working hours will be 40 per week. Your standard hours will be 9-6 Monday to Friday with an hour for lunch.". This part makes me just think it's a formality and i'm overthinking it.
As for the contracted hours, I'm thinking of shooting off an email to try renegotiate it down to 9-5 (With a salary adjustment downwards of course) any advice on the best way to try approach this? I'd obviously explain my position with wanting to go do a degree part time.
Cheers lads
Cheers lads
