Why? VM02 went ahead didn't it? I didn't realise how far down the list Voda were. And 3 has always been a small player...I suspect the CMA will block this.
Doesn't 3 rent their network from MBNL? I don't think 3 are in the slightest big enough for the CMA to have a legitimate concern tbh.VM didn't have a mobile network, O2 didn't have a cable network, the merger didn't materially erode competition in either space. There is a clear difference with this as both Vodafone and Three are first and foremost mobile networks.
Going from 4 to 3 will erode competition and consumer choice in the mobile telecommunications space, its a really obvious thing they will block.
Before the VM/O2 merger and the BT/EE merger, imagine what the answer would have been if BT tried to merge with VM.
No, they have their own network and some of the best 5G spectrum there is available. Three rent their network out to others- ID Mobile and Smarty.Doesn't 3 rent their network from MBNL? I don't think 3 are in the slightest big enough for the CMA to have a legitimate concern tbh.
Three UK are embarrassing all the other MNO's with their 5G roll out, with EE running a close second. If anyone will benefit from this it will be Vodafone, as Three have 100MHz of contiguous spectrum in the n78 band and have more 5G mast applications in progress than nearly all the others put together.
I really hope that if this goes ahead that Voda3 retain some value tariffs, rather than making it worse for the consumer.
It will be coincidence.I’ve been a 3 customer for years, mainly due to the fact that I used to travel globally for work, and their Feel At Home perk was about the best roaming package going at the time. However, 3’s signal when I’ve been at home has always kind of sucked, and now that I have a job that means I no longer need to leave the UK, I was considering switching to Vodafone just before this merger was announced. Since then however, I’ve noticed that I’ve gone from being lucky to have 1 bar of signal, to 2 or 3, and no more dropped calls or me having to walk out the front door and into the street to make or receive a call.
Not sure where the merger is upto at the minute, but I guess I’m possibly benefiting from using a Vodafone mast that’s nearer to my house than a 3 one.
What are POW’s?You are just one of the beneficiaries of Three's aggressive role out of their POW's.
