TeamViewer not getting secure connection via WiFi
6 Jan 2013
Rollergirl
My devices can't connect to TeamViewer via my WiFi, however have no issues on mobile internet. Any ideas out there on what I need to tweak in the router?
Router is TP-Link AC1200
Have you checked to make sure that your WiFi network is listed as Private and not Public? And subsequently, the firewall as well to make sure it's being let through on the Private networks? (Obviously you want it off on the Public ones)
If your ISP is TalkTalk then they block TeamViewer by default because it gets used so commonly to scam people. You need to turn off some of your protection settings in your TalkTalk account.
What's the use case? If personal, Windows has a free utility for example, which is client to client and doesn't go through cloud servers.
It was really just a general question, TeamViewer accepted my argument I only used it to help friends out so it works well for me. I guess usage is all Windows but version does vary.
What is this free Windows utility?
From my understanding there is something built into Windows 11 Pro, but I'm using Windows 11 Home and my Plex server is running Windows 10. Will the free Windows utility work? Would be interesting to know which alternative to Teamviwer people are using for the basic needs I use it for (moving the odd movie into a movie folder, possibly running windows update every couple of months).
There's Remote Desktop for managing your own machines, and there's Remote Assistance where you can grant access for someone else to remote onto your PC.
