It may well be.
Come on then, where's your source?
It may well be.
Basically any possible TfL subsidy is probably payable out of the tax take of Londoners alone multiple times over. If you were to divide the tax pots and spending into say "London" and "the rest of England" it wouldn't be London coming off worse. And without TfL a lot of that tax wouldn't be being made in the first place.
The home counties such as Kent are net contributors to tax too,and also get less overall spent per capita compared to London. London tax contributions are also somewhat warped by the contributions of the financial district too. The high speed lines into London are mostly for the benefit of London,ie,easier to get workers and tourists into London. Those people end up spending money which benefits London. But the issue all of this infrastructure is mostly paid via general taxation or higher fares for people in the home counties if they use the main line trains,even if you are not going into London or are forced to pass through it to go somewhere else,even in the same country(!). So you could argue people in places such as Kent are also subsidising London to some degree too. In Kent for example,the so called "high speed zone" starts from Ashford in Kent which is nowhere near London. That money should be better spent on improving other infrastructure too in the outlying regions. Then there are London centric infrastructure projects such as the Lee and Tideway tunnels,HS2,which are being funded via general taxation.
I don't actually disagree with any of this, in fact for a good few years I used HS1 myself. But it's not actually a zero sum game. The reason they spend money in London is because it's expected that doing so will ultimately generate more economic activity than spending it elsewhere. The effect of spending that money there can ultimately generate more money that you can spend in other areas. Like you could build the Elizabeth line through Canterbury but if it ends up being permanently underutilised then what's the point?
Why are people not in London having to pay higher fares,or having to use arbitrary routes passing through London? This makes the journeys slower and more expensive. There used to other routes a few years ago that didn't do this and are now gone.Even bus travel in that zone,is very expensive,because for some reason everyone thinks locals have London pay.
But Canterbury train travel is not affected by the so called "High speed tax" which is more a London tax pushed on anyone in Kent who is happens to be closer to London,but also won't get London weighted pay. So Khan might moan about Londoners subsidising Travelcards. But I suspect all the people in Kent,etc forced to pay higher fares for instructure which helps London,forced to pass through London to go to parts of the same county,etc are probably contributing directly or indirectly far more money to help London out than the so called Travelcard subsidy.
You are even paying this stealth tax even if you are not going into London. We all know ULEZ will eventually become a new congestion charge zone,and anyone travelling from outside London will pay it. Then on top of that Ashford International was supposed to mean people didn't need to go into London if they wanted to go into France. But OFC,in the end as usual that fell to pieces so,now its back London getting more money.
OTH,a silver lining if all of this is maybe it will push more people in the home counties to start spending locally which will be better for the local economy.
For the first bit about having to go through London, I'd blame that Beeching fellow for that. But really the cost there is motivated by the fact that TFL is unusually fare heavy in terms of its funding compared to other transport systems which are actually more subsidy heavy.
On the ULEZ becoming a congestion charge thing, probably better to cross that bridge when we come to it otherwise it sounds like tilting at windmills.
On Ashford not getting international services, I agree that completely sucks. Pandemic seems to have hit Eurostar hard. I've got the same issue with Ebbsfleet (even if it is just a glorified parkway for Gravesend). Total waste of potential.
Yeah I think the incentives to redistribute geographically are no bad thing as well. Same thing with WFH, it should have been encouraged but seems like people with a stake in commercial property etc. have a lot of sway.
In the last few years,there were alternate routes which didn't pass through London which were cut. Because we all know they could charge more for the routes which pass through London. OFC nobody can explain why regions which are not part of London/London weighted pay are being charged London weighted fares even if you are heading away from London. None of the political parties give a damn it seems.
OFC ULEZ will become a congestion charge like thing because all the infrastructure is there with ULEZ and the central regions of London where his voter base is strongest won't be affected because the public transport is functional and car ownership is low. The people in the outer boundaries are more likely to need a car anyway. Free money. No political risk for him personally.
I like to see what happens if Labour wins next year if they will fix any of this. They won't have the excuse anymore the Conservatives are blocking XYZ.
Labour's entire thing at the moment seems to be to say something along the lines of "well the Tories have screwed everything up so much that we have to do exactly what they would have done anyway" so I wouldn't hold my breath.
Travelcards combined with mainline are really expensive now though, for me at least. It's cheaper for me to buy non-travelcard tickets and then pay as I go using contactless for my normal commute (£5.60 on contactless whereas a day travelcard costs over £10 more than day return). And tbh that's if I go the lazy route of buying a return, it's cheaper using advance single tickets which you can't get a travelcard on even today. Buying advance tickets and using contactless for the tube costs over £30 less than buying a day travelcard.Understand but as far as I am aware that does not constitute as a mainline travel card, just a zone travel card.
From my understanding this was an attack on the commuter belt of London, those who need travel cards to maintain a sensible price for travel in to the capital each day.
Where I live, I can buy a travel card for £32 that gets me to my london mainline station and then I can go wherever in london for that price.
If I do that separately, it ends up being about £40 a day, does not sound much but this is just where I live and my experience, colleagues that are living further out are more towards a £50 travel card and £65 without. It all adds up.
Either way, removing travel cards is another attack on the commuter belt and commuters in general. Plus it allows me to actually spend some time in the capital and spend money as I can then move between stations, see some friends etc etc. Doing this on a oyster and normal train line ticket, all it does it add even more money on to my already expensive commute.
The way I see this is:-
Government decides to remove TLF funding because the rest of the country shouldn't need to pay for something that isn't benefitting them
Covid hits, everyones finances gets screwed. TFL is no exception.
Government has TFL over a barrel in return for funds.
TFL now seeing an opportunity to make some money by deciding londoners will not subsidise outside travel cards. (if i understand it correctly)
And we've gone full circle. 1 & 4 are both dumb, the government needs to realise, AFAIK, public transport isn't generally profitable and trying to force TFL to fund itself is dumb as rocks. TFL/Mayor need to realise that funding tickets from outside london is a good idea - transport in the UK isn't exactly cheap, allowing people to come in and spend is a good idea. If they want to increase the ticket costs they should do so by a far smaller amount - £3 at most.
I do think we should bin paper travel cards though, I'd have it integrated into oyster in some way.
Probably because:-
