- 18 Feb 2021
- Worcestershire
Hi all for the past month or so I've been having some instances weather it be gaming, or just general web browsing my screen to my lg nano cell TV will go black, I've tried new hdmi 2.1 cables as my TV is a 50 inch 4k 120hz TV
My pc spec is as follows
Ryzen 5800x
A Asus x570 VIII hero atx board
MSI gaming trio Rx 6800
64gb of ddr4 running at 3600mhz
And finally the PSU is a 3 year old Corsair tx850m semi modular power supply
I've made sure everything is seated properly
The GPU is installed correctly and made sure the screes are tightened correctly
The reason I'm thinking it's the PSU is I was gaming in the evening about 10pm recently and had the volume quite low and when the screen went black (happens every hour or so and then nothing for the rest of the time) the pc sounded like it was struggling almost like I could hear a stuttering noise coming from the fans and PSU
I've currently locked my GPU to 60hz and this has cut the black screens to the point where it hardly happens or happens maybe once every five or so hours
I've kept the system running pretty much stock other than xmp for the ram, has anyone else had this kind of issue before?
I've got no problem purchasing a new PSU , I checked the temps of the GPU and it is running (60c when gaming)
Thanks for reading and hopefully can get to the bottom of it
Ryzen 5800x
