You been practicing?I should be good![]()
Naah I'll still suck, just meant I'll the thereYou been practicing?
Do you chaps use an external powerbanks?My battery just died and shut down the headset, about two seconds after warning me the battery was low. I can't start it back up until it charges a bit.
Usually get about two and a half hours out of the pro, but I've got a power bank that fits in my pocket and I run the cable up under what I'm wearing (usually a t).Do you chaps use an external powerbanks?
something like : Anker power bank 737
has come up for others to extenede the headset play time, bonus people seem to also use if for steamdeck
I've got my pulley system still from rift days, cracking bit of kit that.I Don't. I have the USB cable on a ceiling mounted pulley system, that I had for the Rift. So it doesn't annoy me too much when I have to plug in the cable. The problem for me is that there used to come up two warnings, one when the battery was low and one when it was very low. And I would still have time to plug in the USB cable after the second warning. The last couple of times we have played, only the first low battery warning flashes up, then the headset shuts down. No time to plug the cable in.
Might consider a battery bank if I don't switch to the Quest 3.
