- 21 Apr 2007
its not often I ask for help but this one is tearing my hair out...
I have an Asrock X670-E motherboard paired with a 7800X3D and its been doing fine on 32GB (2x16 dual channel) 6000Mhz CL30 etc etc, I've recently bought more memory same make/model/sku to double up to 64GB (4x16) and its giving me real head aches.
To cut a long story short with all 4 memory modules installed I can clear my CMOS setting and get it booting fine at the lazy JEDEC settings which knock it down to 4800MHz and I assume some very slack timings but these memory kits support EXPO profiles and when I select that in the BIOS with AGESA timings, competitive or aggressive (which the previous memory was fine on) I cant boot and have to reset the CMOS again.
The FSB ratio etc is all on auto...
My use case is PC VR gaming btw, that's where I need the performance.
Is my memory crap?
am I doing something wrong?
am I being unrealistic trying to get 4 x 16GB modules running at the EXPO speeds they are claiming?
does it matter if the memory settings come down and I'm being overly OCD about it?
Is my memory crap?
