DDR5 June buying guide [still relevant]
4 Oct 2019
Queens Park - London
Hi all
There’re a ton of “what RAM should I buy” threads so here’s a DDR5 RAM buying guide from Buildzoid.
Mods, please let me know if this is not allowed but I can’t see why it wouldn’t be.
TLDR:
Want a cheap kit that you can overclock and is stable and fast? Get the TEAMGROUP T-Create Classic 10L DDR5 32GB Kit (2 x 16GB) 5600 MT/s
CTCCD532G5600HC46DC01​
AMD: go buy Hynix XMP 6000 MT/s CL30
Intel: 6800 MT/s CL30 A Die works on almost any Intel 13th gen.
For a good Intel RAM get Corsair 6600 MT/s CL 32 for good out of the box performance using XMPs.
24gig modules can overclock better than 16gig modules (will elaborate).
Intel memory controllers are all over the place and are often weak or even rubbish.
Z690 boards are no way near as good at posting high end RAM speeds as Z790.
2 DIMM motherboards are much better at DDR5 Overclocking.
Edit: Here's an Intel memory scaling guide from Hardware Unboxed with help from Buildzoid
Regards
Is that a 2 dimm board or dose a 4 dimm board that’s running just 2 dimm work just a good?
As Tetras said, it’s a 2 DIMM only motherboard rather than a 4 DIMM with only two modules installed.
You can get better stability with only 2 DIMMs installed in a 4 DIMM motherboard but it’s not as good as a 2 DIMM only board.
You’ll also see dedicated overclocking boards also put the 2 DIMM slots as close to the CPU as possible to improve RAM overclocking by shortening the connecting traces (such as the evga z790 kingpin).
Added the Hardware Unboxed Intel memory scaling video which was created in collaboration with Buildzoid to the original post so that it doesn't get lost in the thread.
Anyone tried the 32gb sticks?
It looks great memory but I can’t find any UK sources, just US imports with no warranty.
The 64gig kits (32gig by 2)?
Those are pretty niche kits but I'm sure someone has them. Maybe look at US forums for insights.
As for how to buy a pair, why don't you PM/email the OC mods/sales team?
Hi mate,
Yes, 2 by 32 Gigs. I'm sure @Gibbo looks at the forums, not sure why they don't. Look great kits.
Hi mate,
Maybe the number of people who make use of those RAM kits is so low that it’s not worth putting on the website?
I would stock the 64gig kits to cater for the high end users as they are the kind of users who would buy a 4090.
I don’t know why the 48GB(2*24GB) are not more popular, If I was buying now, I would get one of them. OC’s DDR5 range seems limited and expensive compared to other places.
This is the exact set though i've seen a set rated for upto 7200mhz thats meant to be really good.
If i can get upto 7000mhz that would be a treat! Probably have to wait for 14th gen for that though with a more mature MC.
The 48gb kits seem to be quite abit more expensive and timings don't seem to be as tight, unless im reading it wrong.
Prices are all over the place and the 48/96 GB kits tend to be higher frequency kits. I was going to get a 96GB kit, the price jumped £100 in a day so did not bother. Also, most kits are XMP, but AMD kits are slowly starting to show up. Hopefully better kits will appear soon.
I don’t see the point of 48GB when you can get 64GB for around the same price. Two strips is generally the better option and requirements only go up. 16GB used to be enough, now 32GB seems to be the new 16GB norm. Obviously depends on what your doing with your pc.
I agree, the 64GB kits have dropped in price a lot. That said the 48GB kits are single rank so work the same as the 2*16GB kits (same number of chips). The 64GB kits have 2 * the ranks so it’s harder to get stable at higher frequencies (2 * the ranks could be a little faster though, like with DDR4). Samsung has now done 32Gb dies so we may get single rank 64GB kits but probably not for a long time.
Do you have to have Hynix A die?
Seems to be the best that gives you options. I’m sure Samsung will perfect their dies to achieve higher / tighter timings so in no rush. Running the default 6000@36 which is on Samsung B Die, can push 34 with 1.38 volts but seems hardly worth it.
