2700x holding back 6800XT?
6 Jan 2013
Rollergirl
I've just gifted my brother my 6800XT and his system has a 2700x and monitor is 2560*1080 resolution @ 120Hz
I didn't get a lot of time to test, but the few games that I did test, performance wasn't what I was expecting - some games were not utilising the GPU 100% and when it did hit 100% in e.g. Ghost Recon then there was some hitching going on.
Is the 2700x a big bottleneck? The card it replaced was a 1080ti so maybe there's a driver conflict? I did clean with DDU but you never know..
Edit to add before and after benchmarks:
Timsespy
Firestrike
In some games it will be, yes, especially @ 1080p. But, I'd still expect the games to run 'alright', so I guess it depends what you mean by hitching.
When I bought my son a 6600xt I noticed quite a bottleneck on his 2600 and so I upgraded him to a 3600x which helped loads. My youngest is running a 2600 with a 6700 non xt and hits 60fps most of the time but still gets CPU bottleneck on some games. I would suggest a 5700x or above will improve things a great deal.
By hitching, I mean when the camera pans it can pause for a split second.
I've got a 3700x here that I could drop in but not sure if that'll make a big difference or if I'd be best trying to pick up a 5000 series.
Got to be worth an hour of your time just to see if it improves things and then make the decision.
I had a 3700x prior to my 5900x and it ran things well enough but 5 series made a big difference
I think people forget how bad first and second gen ryzen were... In gaming terms 3rd/4th gen intel at best. 3rd gen got competitive and 5th gen finally got on top.
Edit: in gaming terms only
I don't game but my home PC's 3900x feels faster than the 2700x system l am using at work. Hopefully, there will be some nice deals on 5800x/5900x on Black Friday.
What kind of difference would a 5700g make? I'm not up to speed with the "g" chips; they've got integrated graphics capability, right?
5700g does have intergrated graphics but is pcie3 only not that will make a difference but
It's Not enough performance boost imo the x3d is the best choice due to its huge v cache.
if you already have it... it will be faster than a 3XXX chip. but if your buying then get a none G, the 5600(£100 used) is a fast little cpu you dont need a 5700.
did you drop in the 3700x? i dont see the 3700x holding back the GPU.
run some bench marks and see how you get on
