- 8 Nov 2006
- Scotland
So had a play around with my 2080ti
Power goes to 108%
Does have an effect when change from 100%
But unlocking the voltage slider and changing voltage
Has no effect
Won't go past 1.043v annoyingly
Board power hits 280w at 108%
Overclocked core to 2050mhz
Overclocked vram shows in gpuz was 1750mhz now 2000mhz
Or 7000 now 8000 in xtreme tuner
Probably a little bit left to go but I just did
A very quick overclock
Gpuz perf cap is for power and vrel
So it does overclock at least
So question is
Will flashing another bios really make much difference?
If that voltage would actually go to even 1.1v
Then would probably be happy with it as is
If so
Not done this in ages
Better to flash in windows?
Or in dos?
@Audioboxer
This is my card
KFA2 GeForce® RTX 2080Ti EX (1-Click OC) - GeForce RTX™ 20 Series - Graphics Card
<div id="featurebullets_feature_div" class="feature" data-feature-name="featurebullets"> <div id="feature-bullets" class="a-section a-spacing-medium a-spacing-top-small"> <ul class="a-vertical a-spacing-none"> <li><span class="a-list-item">Real-Time Rawww.kfa2.com
This is bios I am eyeing up
That BIOS should flash with regular nvflash from the techpowerup site.
Just command line flash with nvflash64.exe -6 abovebiosromname.rom
NVIDIA NVFlash 5.867 Download
NVIDIA NVFlash is used to flash the graphics card BIOS on Blackwell, Ada, Ampere, Turing, Pascal and all older NVIDIA cards. NVFlash supports BIOS
Here is some guide info you might need to do protectoff command first https://itigic.com/nvflash-how-to-flash-a-bios-on-an-nvidia-graphics-card/
