I'm not sure where you're getting your info from
you previously stated there's a 30 mph limit on roundabouts.
Why weren't you in the right lane? Cutting across a lane at a roundabout is always best avoided.
Mainly the Highway Code.
I was taught that 40-odd years ago.
For me the only thing that makes sense here is that the left lane should always be taking that exit, right lane can go around or take the exit.The same could be said of the other driver![]()
True but you can anticipate that people are going to do either manoeuvre, I'd say it's more likely that someone is going to turn left in the right lane than it is someone in left lane cutting across and going right, although both do happen often.The same could be said of the other driver
505/50 is my guess.
I can neither confirm nor deny that the insurer I worked for was located anywhere in the locale of St Davids Shopping Centre or CIAThanks for the replies, I assume “admiral” being a major car insurer. Will see what happens.
though they also aren't the only major insurer in S Wales or in Cardiff for that matter
