Wheel nut torque value
I have a torque wrench that I just set to 90 ft/lbs. Do all my cars to that rating.
Unless it a 4x4 which require a bit more or something weird but most passenger cars will not need more than this.
You want to be careful of anything like grease, oil, even paint near the bolts - people have resprayed alloys before and the material where the nut goes against the wheel has then flaked/compressed/changed after the nuts are torqued up, resulting in the nuts being slightly loose and working until they come off...
Just had a look on Autodata for you..
Steel 88Nm
Alloy 114Nm
I didn't know alloy needed more torque so I used 90Nm on my wheels a couple years back and after a few months of driving one of the wheel nuts popped out and the other on that wheel started coming loose lmao. Then torqued it to 120Nm I think and never had that issue again
See, the smart man would have took one nut of the other 3 wheels and then you be running with 4 nut. But i guess 1 nut on the wheel and 1 nut behind the steering wheel working well for ya. :D
I was only 500m from home, it was 3am and I was 17 :D
Tbf it was a long time ago, I mightve done. Who knows, it ended fairly well though. Apart from having to drag a jack down a hill, then being questioned by the police. Who obviously didn't believe me.
So yeah, I torque my nuts now.
I torque them to the specified value, obviously dry.
I do, however, put a thin smear of copper grease on the inner surface of the rear wheels which mate with the outer part of the brake disc on the hub (taking care not to get any near the holes for the wheel studs/bolts), to stop the wheel seizing against the brake disc.
Remember if your fitting brand new alloys to recheck the torque of the nuts/bolts soon after having driven on the wheels. The alloy can compress on first fitting and results in loose nuts.
I thought wheel nuts were meant to be checked after a few (50?) Miles and re-torqued but bolts don't need it.
