The yoke was badly implemented because they should have used a variable rate steering system like the Lexus that also has a yoke style "wheel". I think it made your hands move about too much so it was harder to use the touch buttons. I'm sure most people will get used to it because it's different from what they were used to.The relentless push for stalkless seems really weird from Tesla. The reviews I saw of the yoke with the buttons for indicators were all exceptionally critical.
It still a very bland looking car inside and out though.
>It looks like a reasonable update. The biggest selling point has to be the updated suspension - it’s probably the weakest part of the existing model 3. Ventilated seats are also a nice addition.
I can see that no stalks is going to be a very marmite thing, probably causing lots of opinions from people who have not used it. I’ll reserve judgement until I’ve driven it and <insert BMW driver joke here>
No mention of towing weights on the new chassis or if the boot opening was any bigger - it didn’t look to be.
The fog lamps look to be quite subtle now and the lights on the rear when the boot opened look very small - looks to be a better solution than the BMW iX though.
No changes to the motors and batteries but improved range from lower drag.
No but it also has a standard steering wheel, sans stalks of course.Have they used variable rate steering system? Maybe I should watch the video
yes that should be good too if it’s effective.And the improved sound insulation.
By far the biggest for me was the fact it was OPD or nothing.
The Stratford branch is poor in my experience, we ended up going to the one in L/Spa for our last car (non EV) which was much better.So, my delivery for the ID4 is confirmed for the 2nd October. I have to admit, the comms from Lister VW at Stratford-upon Avon this week have been poor. First car delivery was from the 6th onwards, nope scratch that we can't do those dates. Settle on the date in middle of September. Receive another email saying that Zenith won't release the car for delivery until start of October.
If it arrives on time, then it would have been just under 10 months from order.
I still need to find out if we have chargers in the office.....I suspect not.Bug your work to put free chargers in the car park![]()
Had a look at charging at home briefly..... Ovo just flat out say they won't install if you don't have off street parking.@mid_gen Generally I don't recommend EVs to people that cannot charge at home. But I personally know one person who it works fine for, but then he is the type to actually enjoy a little extra planning.
So it comes down to how commited you are to the cause. Sounds like you have backup car anyhow.
Most people charge regularly, rather than use 100% to 0% as EVs generally charge up to 80% at a much higher rate than 80-100%
I would assume you will save time by doing a 10 minute charge after your first day in the office on the 58kWh and only charging over 80/90% for road trips.
Avoid the big companies as they tend to still follow the OLEV rules for chargers which they are paying grants towards. The grants for home owners ended long ago.Had a look at charging at home briefly..... Ovo just flat out say they won't install if you don't have off street parking.
Is this a common thing? I've seen people charging with a cable across the pavement, but is that limited to just a 30a plug?
