VR headset for glasses user.
With glasses i've been a bit paranoid about them slipping and then touching/scratching the VR lenses. Ive used some glasses straps which you can tighten to prevent this.
Best solution is prescription lenses then. But choose the headset you're going to use for a while as generally they aren't compatible between headsets with a few exceptions.
