Possibly bad memory
1 Sep 2013
Been having the odd system reboot and crash to desktop on my system I've yet run to run memtest
Reason for me pointing the finger at the ram is since disabling xmp it seems to behave itself but when enabling xmp it starts crashing again I've tried manual setting the ram speed to 355 and crashes then aging to 3455 I think is the setting and crashes are less
System is over 3 years old the CPU and GPU are just under 12 months old and have been running great till now
Bios and drivers and windows all up to date
CPU 5700x
Mb MSI b550 mag mortor
GPU red devil 6650xt
Ram 32 gig Corsair vengeance
Any ram you guys could recommend for my setup
Thanks
Windows has an inbuilt memtest if you don't want to fart about with usbsticks and the like, just type "Windows Memory Diagnostic" into the start menu, it'll launch on next reboot and you can select different options like how many passes and test difficulty etc.
Don't have any ram recommendations for you though, since I generally just go with whatever the maximum CPU supported level is, and that stuff is generally cheap anyway.
Didn't know that cheers mate
Is that 2x16gb or 4x8GB sticks? if 4 then test going down to 2 sticks.
2 sticks of 16 gig
2 sticks of 16 gig
Cool the RAM first and see if that helps.
Check what voltage you’re at - manually set the voltage to 1.35v and see if that helps. Not all motherboards apply voltage equally and Gigabyte are the worst offenders (I know you have MSI, I’m just saying you need to test all factors).
Also check that you’re on the latest BIOS.
Then remove one stick and test that using TM5 with the ANTA777 extreme config.
Then test the other RAM module.
Replace RAM if needs be.
