The BMPT's guns are stabilised both vertically and horizontally. Not sure if that dude is making that mistake because he's reacting to a promo video of it doing cool stuff instead of actual combat use, or if he just doesn't understand what he's looking it.Main gun(s) on BMPT72 arnt stabilised, and are mounted way to close (conformant recoil harmonics) - eg, both guns reinforce each other for bouncing after shots fired. This massively reduces accuracy
In combat they are normally loaded with separate ammo types, I.E one with Armor-piercing discarding sabot and the other with High Explosive Fragmentation so that the unit can engage different target types without the need to reload. You wouldn't see it firing both at once* unless it was just going for overwhelming fire (target deletion rather than destruction) or just doing a promo video.
*Not that it actually fires both at the exact same time, even when firing both cannons they alternate.
It's a really weird thing, because they originally designed it to compliment/support their tanks, but it turned out to be pretty much completely superior to their tanks as it has the same survivability, superior anti tank performance*, superior anti infantry performance, superior anti-building performance, superior speed, superior range, and actual (although limited) anti-air performance. The only thing it can't do is indirect HE shell fire (which tanks shouldn't ideally be doing anyway).Thought I'd have a quick looksie and see what they were
*On paper it "only" has four ATGMs, but it's not like any Russian tank is winning a 1v5 encounter.
