Caporegime
- 7 Apr 2008
- Lorville - Hurston
Id get a bosh or Vaillant one if you are able to choose. Both tried and proven companiesJust says a Daikin heat pump.
Ahh right ok fair enoughDaikin is a leading if not THE leading brand in the heat pump space. They have literally been making them for decades.
Bosh and Vailant on the other hand are are new entrants who are known for making gas boilers….
Interesting; I also had a call but was left for voicemail. Central heating in my gaff is currently copper piped which appears to be 12mm (definitely 10mm). I don't suppose they indicated either way if copper was still viable for the installation? I dread at the thought of how invasive it would be to repipe across the entire house (and loft).Had a follow up call with Octopus in regards the heat pump.
I mentioned pipework and that I hadnt measured it but that I was unsure on 10mm or 8mm. He said 10mm is fine.
If its 8mm its unlikely to be ok, but they will do a fixed price repipe. A 4 bed is £3700.
So total to replace would be more like £7.5 (including grant) if the full repipe was required.
Its obviously highly invasive though and I have tiled and hardwood throughout so I wouldn't be doing that at this stage!
For the solar panels, we should break even in 8-10 years. Life of the panels is 25 but inverter will be less.Bet it will take u 10 years to break even though.. Maybe longer.
Solar panels last I checked ain't cheap to install and is quite expensive.
Materials for it is expensive and the labour plus scaffolding is also not cheap.
Did you already have insulated walls? Roof and ground floor insulation?
Did you also already have suitable radiator sizes and also a place to store the hot water cylinder tank?
Get an induction range cooker. Much better than gas and will save you faffing about with gas tanks.I don't think its an issue if its copper. He didn't give any indication it would be, just that pipe needed to be 10mm or above. I assume he was talking external, he didn't specifically say.
Just doing a visual comparison of a aaa battery (listed as 10.5mm) vs my piping it looks like its 10mm anyway. Will confirm at the weekend when I will dig out my vernier to check for sure.
Hes going to call me back in a week or so before my fixed price quote expires.
I need to have the what if conversation indoors. I haven't mentioned it yet.
The biggest hurdle will be the external box as shes into "traditional" plus the fact we have a relatively new range that is gas.
So I would need to add £1.5k or so to replace that as well I am sure.
I could leave it but I am not sure the SC for gas really makes sense for just hob usage. Would need to play with some numbers.
That's an opinion, one I strongly disagree with.Get an induction range cooker. Much better than gas and will save you faffing about with gas tanks.
And Sunak did announce that grants for people under the boiler upgrade scheme would be increased by 50%, going up to £7,500.
I was just about to post that. Great news for you and anyone else looking to switch to ASHP.Wasn't expecting this but plans to upgrade the BUS scheme to £7.5K grant instead of £5K, would make this a lot more appealing.
UK net zero policies: what has Rishi Sunak scrapped?
PM has outlined plans to delay some climate targets, saying they will save people money. Experts give their viewwww.theguardian.com
Fair enough. Maybe depends on the cooker.That's an opinion, one I strongly disagree with.
That's a bit rubbish isn't it. 5 years is that all they reckon it'll last before failure on average.Can only go off the Octopus quote as its all I have
- Your heat pump comes with a 5 year warranty and a 2 year warranty for other products installed (such as hot water cylinder and radiators). As well as a 5 year Workmanship and Labour Warranty.
Why? They were not giving the £5k discount, the government was. The price should reduce £2.5k.That increase from 5k > 7.5k is going ti screw up all the individuals, including me, who only recently got an Octopus quote! I'm pretty sure they will not accept a further 2.5k reduction in the provided quote without a means or method for them to skim![]()
Well, we'll see. I replied to Octopus with this exact query.Why? They were not giving the £5k discount, the government was. The price should reduce £2.5k.
