Yeah I would think that the 5 is going to be a banger of a case. to be honest the only reason I'm going with the 7 is because I plan to shift towards WC further down line and I want a lot of space to work with.Yeah same, might go for the NV5 though. Apparently August release date.
According to Reddit, in OctoberAnyone know any more news on a release date for the NV9?
Was going to wait for the lighting kit to come in stock but ordered the NV5 in white whilst stock still available, here tomorrow hopefully.
Providing everything turns up ok tomorrow will be building it FridayPics and your thoughts when it arrives![]()
Really want to build a system ASAP with this but the White Revolt PSUs aren't in stock yet. This case looks perfect for me in terms of look, cooling and form factor. The case + cooling + power supply should last a long time (thinking 7-8 years).Build finished for now until the lighting strips come into stock,
Only issue I had with the build is getting the 24 pin through the rubber grommet, it needed the cable tidy behind taking off first, pushed cable through and screwed it back in, loads of room for cabling in the rear, didn't feel like I was fighting the case for space unlike the Fractal I've switched from.
Plugged all fan RGB into the case via daisy chain instead of having to use motherboard to control it and can use the 2 buttons on the case. Imo it could do with a small fan hub (especially as cases cheaper and around this price point do come with them) then again not a major issue with the amount of headers on most modern motherboards.
One thing to note is you only get one dust filter for the bottom of the case, the side doesn't come with a filter.
Without glass front / side:
*snip*
With glass front / side:
*snip*
Moved where the gpu power cable ran after taking these pictures so it comes up the middle of the gpu instead of the side.
AIO was the easiest I've installed, literally put the backplate on tighten 4 screws and away you go. Went for the Phanteks glacier D30, to finish it off as the only other AIO I had was an Artic which didn't go with the look I was after this time around.
For £95 with the white version it's plenty of case but if you haven't got fans already that's where the bulk of the cost will go (granted you don't need D30 fans)
