- 3 Apr 2020
Morning guys, Looking for some advice please, What would you say is the best (preowned) GPU for 350-400. Is it still the 3070?
Thanks in advance
Thanks in advance
Should be looking at a 3080 for that price.
£400 New ?or the 6800xt if you're not averse to going AMD
Thanks in advance
No he mentions he's looking pre-owned.£400 New ?
Apologies it's Monday morning.No he mentions he's looking pre-owned.
New he's looking at a 6800 or even a 6800XT if a good offer comes up (6800XT isusually nearer £450 but occasionally have dipper below 400).
Everything there is poor value. There are better brand new options at your budget rather than a second hand 3070 from CEX.Great advice so far guys! I have a £400 CEX voucher hence why I mentioned the 3070
6750xt is a slightly Overclocked 6700xt which is not worth it for 1 to 2% boost, 6800 is on average 10 to 20% faster than the 6700xt depending on the game.What are peoples thoughts on the 6750XT? Is it worth the jump to the 6800?
www.techspot.com
The more I'm looking I think the 6700XT is going to best value for me. If it was a choice between that and the 3070 where would you guys tend to go? Thanks all again by the way for the input
If you can it's worth the extra.Ok so I should really be going for the 6800 then
