I think any form of terraced is going to be difficult to do it.
You can get cylinders around 470mm diameter.
I'm going to wait so many questions they couldn't answer when I asked them to phone me.
Location would be an issue for us as well it could go at the front of the house but that would be ugly as hell, at the back anywhere with space would be right under a window.
I don't want it on the floor either as that means when we relay the patio it would be in the way.
I'm going to keep an eye on the efficiency of them, they only going to get better I imagine. I'll get my own cylinder at some point and if there is no grants at the time I'll fit the whole thing myself save plenty that way.
When you say roof mounted you mean on the roof or in the loft with ducting.
That would be ideal for me as well.
I think what needs to happen is electric prices to go way down, or what's now likely gas prices to go way up.
They also weigh a lot and you’ll never get one up there. Those roof mounted units are craned in. They make some sense in a new build but would be very expensive to retrofit.You need a whole load of free air around an ASHP for it to work. They can't go in lofts.
Noise would be my biggest worry with a high mounted one, don't want to listen to whirring fans while trying to sleep.They also weigh a lot and you’ll never get one up there. Those roof mounted units are craned in. They make some sense in a new build but would be very expensive to retrofit.
You’ll probably get planning permission for putting one on a boundary these days because they are basically silent. Under a window is also fine unless it’s particularly low or it’s a big unit.
In its defence, ‘effective’ doesn’t mean efficient, however i fundamentally disagree with the point around not having the knowledge to insulate old houses. That is nonsense, the issue is no one wants to pay to do any of the work properly, the insulation point is not even required in many cases, you just need bigger heat pumps and radiators compared to a new build. That’s already the case for a gas boiler….
O come on, Heat pump is not the be all end all. it has its flaws and a property owner needs to assess the current property to see if it makes sense to install one.They probably would notice it because it seems to be a common trend for people to blast their heating system at a very high power output for short periods under the impression that it is economical to run for short periods ignoring that it's probably about a 30kw system. A lot of people simply wont accept running a low output system running for a longer period. At this point a huge number of tabloid readers are completely brainwashed against heat pumps after reading the near daily heat pump bashing articles no doubt backed by the gas industry.
Ist efficient once you have sorted out having radiator upgrades if needed, solar panel to help a bit with the bill, actual room outside to house it in and decent insulation.This article seems like rubbish.
"The real problem with heat pumps is that they are not yet effective enough"
yes...only 100%+ efficient!
Solar panels and heat pump? Why you still pushing that rubbish after being told you're wrong like 500 times already?Ist efficient once you have sorted out having radiator upgrades if needed, solar panel to help a bit with the bill, actual room outside to house it in and decent insulation.
I said it will help a bit.Solar panels and heat pump? Why you still pushing that rubbish after being told you're wrong like 500 times already?
When did this grant become active?It sounds to me a little like buyers remorse after spending a bunch on replacing a gas boiler instead of using the grant on a heat pump replacement.
