- 25 Sep 2012
- Scotland
You are able to buy a 7800xt on another site for £515 currently and it's closest competitor, the 4070, is available for £530.
4070 advantages -
DLSS provides better image quality.
GSync module support.
Better Ray tracing performance.
Lower power usage which at current retail prices actually makes the 4070 cheaper in less than a year if you use a few hours a week.
Ray reconstruction improves ray tracing quality and performance.
7800xt advantages -
Slightly better overall performance. Around 5% at 1440p.
16GB vram Vs 12GB on the 4070.
I feel that the 7800xt is overpriced by around £100 versus the 4070. nVidia's features are worth that to me and I will be saving money on electricity. The greater VRAM helps the 7800xt's value proposition somewhat but I think 12GB will be ok for at least a couple more years.
What do you think?
4070 advantages -
7800xt advantages -
What do you think?
