Hi there been looking at your work well done great thread.
got a 2080ti that has started to artifact reckon you can fix it ?
Oooof so it's a memory chip issue ?You could change out its memory - It is absolutely doable but not sure I would take that on tbh - GPU's are generally a royal pita and an artifacting 2080 doesn't sound like fun given there are 12 gddr6 memory chips on the thing... what does sound like more fun is doubling its memory- Taking it from an 11gb card to a 22gb card could be fun but you are looking at a £150 investment into gddr6 memory modules.
It's got rhe Samsung chips thought they were better.
Tried undervolting and other things I could try first bud ?
Will try thank youdrag the memory clocks back a few hundred mhz. It's almost always a dying memory chip but I guess it could also be a memory controller which are on die.
Will try thank you
done the oven trick and appears to be fine ?
22gb wowsers how would that compare to the latest cards ?
Depends how strapped for memory the 2080 is... I would say it wouldnt make a massive difference outside specific memory heavy scientific workloads
Still a case of working out which one though?seems to be running fine now lol, is it still worth repairing replacing the one chip or ?
Got some soldering done today - removed a Dualsense thumb stick and replaced it. Bloody hell that was a lot of work getting the original one off! I thought the desoldering iron would make it easy, but not really, needed a lot of braid and flux with a normal iron to get enough solder off to remove the stick without damage.
Clearly I need to improve my desoldering skills. Must’ve taken at least 3 hours in total!
Guessing you need a hot air station for that…and it just works with those thumb sticks without anything fancy, just decent flux? If so I’m sold, has to be worth getting one rather than spending hours painstakingly removing all the solder with braid…would probably pay for itself quickly too, given the amount of braid I go through!The trick on these is not to desolder at all but to go from behind with the hot air and just let them fall out![]()
Guessing you need a hot air station for that…and it just works with those thumb sticks without anything fancy, just decent flux? If so I’m sold, has to be worth getting one rather than spending hours painstakingly removing all the solder with braid…would probably pay for itself quickly too, given the amount of braid I go through!![]()
