*** The New Cases Gallery ***
Asus ap201 matx case. Built a new system yesterday, great to build in and a lot easier than my phantek itx case.
finally put together my new AIO and NVME driver in. Not the brightest, but im sure at night it will come more "alive". Also to note, the tubes for the AIO look a bit kinked but its just the photo angle.
Tough to make out from the image but is that the new EK nucleus AIO?
Really nice looking build!
No mate, its a DeepCool AIO. I use a few of there products, really underrated imo.
Thanks! its not to bad, considering the space to work with..its a DeepCool case too, which I do like, but defiantly on the smaller side though.
Ah! Nice, I like the AIO - really nice subtle RGB to it.
Modified the crap out of a nox hummer vault I got the other day.
It worked out pretty well, it's not completely flush on the bottom as you can see, but once the side panels are on its not very noticeable (the side thats the worst is a side i can't see anyway)
Bought the case a bit blind and the PSU was too long for the 3080, until now...
https://i.~ibb.co~/GPSkdjQ/PXL-20231014-155055143.jpg
https://i.~ibb.co~/ZWcj5h8/PXL-20231014-155404783.jpg
Nothing fancy - Gamdias Talos E3, Kingston Fury RAM, Coolermaster 240mm AIO and front fans swapped for Coolermasters.
https://i.~ibb.co~/MPRFsRV/c1.png
https://i.~ibb.co~/sb0tGDF/c2.png
https://i.~ibb.co~/8PznQqg/c3.png
That is awesome! Love that!
How are the temps on that? Looks a tricky build that!
