Some think the BIOS with AGESA 1.0.0.7c fixed it but I have not tried it, my USB NIC is working fine.Mine seems stable had no disconnects yet on ethernet , but early days since this is my day one.
Mine was built in April 2023, btw mine has latest BIOS.
Thats the new one with AGESA 1.0.0.8. I updated to that the other day.I believe the BIOS I have is 1809 .
I used it on my old PC but don’t know if it’s still a thing as its not on the ASUS download page.Guys is the Sonic Studio 3 worth installing on Win11?..I hear some users have issues with it on 11.
All feedback welcome.
New BIOS available [1813].
Was looking at this board for a new build (or the B650E-F) but the coil whine and NIC issues are making me very nervous.
Mine does not do that.PC still spin cpu and case fans for about a minute after system shut down. Is it a feature of amd Ryzen chips? Haven’t had that with intel.
Just found this, not sure if it will fix it - Check your power settings: Make sure that your power settings are configured correctly. Go to Control Panel > Power Options > Choose what the power buttons do, and ensure that the "Shut down" option is selected. Disable Fast Startup: If you're using Windows 10, Fast Startup may be the culprit.PC still spin cpu and case fans for about a minute after system shut down. Is it a feature of amd Ryzen chips? Haven’t had that with intel.
I’ve disabled fast startup and now it’s acting normal.Just found this, not sure if it will fix it - Check your power settings: Make sure that your power settings are configured correctly. Go to Control Panel > Power Options > Choose what the power buttons do, and ensure that the "Shut down" option is selected. Disable Fast Startup: If you're using Windows 10, Fast Startup may be the culprit.
I had this years ago on a AMD Phenom rig. Not sure what the BIOS is like on Asus, but check the power settings for sleep etc?
Thanks for that!
I always disable fast startup in 10/11 from power options, btw you have one in BIOS as well on Asus ie "
What is fast boot in ASUS BIOS?
New BIOS is out: 2214.
, no issues with new BIOS update, all working fine.
