You ate it allDon’t bother, where’s the curry?!![]()
I'm on mobile. No idea what your second sentence means, having googled it I understand what bbcode is but tbh that meal is digesting now and I CBA to wee around with ****ing jpegs
Fart is about right.Go here https://imgbb.com/ and upload, go down to Embeded Codes and choose BBCode Fully Linked, Copy and Paste here.. Job done you old fart!
Thanks!
I copied the image URL and then pasted it into the image code used here.What can't Imgur just copy and past the ****InG jpeg![]()
Is it because I'm using duckduckgo like all the cool kids are?I copied the image URL and then pasted it into the image code used here.
Do so and I will deleted the image from my post, because if left up it will cause the wobble heads to start imploding![]()
Sounds like effort mate... you did the job, I lost internet points, you can keep them.I copied the image URL and then pasted it into the image code used here.
I'll write a guide if I get time mate.I'll try again one day.
Kofte is the best charcoal grilled meat. I’m now super hungry for a good Turkish grill.Thanks!
Lamb was a bit on the chewy side (mutton?), chicken was good/reasonable, kofte was divine!
