Just finished grinding 340g of Canadian coffee, our usual is the Jamiacan Blue Mountain but we discovered this on our recent visit to Canada and brought some home with us:
I once had freshly ground and roast (that day) Blue Mountain coffee whilst on the side of that actual mountain. That it was in a styrofoam cup did not detract from it being amazing coffee
Do you have this installed yet? If so what's it like for brightness? I've got some of the lily uplights and found their brightness to be really disappointing, especially for the extortionate price.
It is pretty good tbh. I have the Lilys too and echo that about brightness. Maybe its just orientation but this definitely seems to throw better. It is dimmer in certain colours, maybe thats the unfair part of the Lilys - I've only ever had them on fancy colours!
You want to get yourself a Victorian Outdoor Lamp instead.
That's badass. I remember my neighbor buying one of those; me and Dad ended up laying a base for it, rewiring it etc. Throw back to 1995!
Feeling a bit miserable and irritable these last few weeks so decided to get the essentials for making some okonomiyaki to lift my mood. The only problem is I tend to go overboard and eat okonomiyaki 3-4 times a week as its basically my food based crack.
Outrageously expensive outdoor security light, sans outdoor sensor.
So bought as an outdoor security light, which if there is an interest in seeing how different intruders look under pink/green/red would be useful, but will probably be using just white all the time.
Seems an expensive way to add a PIR white light?
Treat your intruders how you'd like to be treated. In this case, fabulous!
I cant think of anything worse (yes i can) than ruining my dark skies with a big **** off lamp but i do have 2 solar ones ,one on top of my sun house and one where ive put the lamp in my utility, both under 20 quid and work great even in very cloudy periods in winter ,they are not famcy pants ones though with disco lights built in
Yeah, my post wasn't intended to be a dig (I see that angry face) :D but more as surprise at that units price for what it would be used for.
Do you have a camera to also capture the 'Fabulous' intruders :cry:
The irony is the unit as it stands isn't a PIR light, you need an external 45 quid adaptor for that to work :cry:
Thanks for this, much better than I thought. This was on my purchase list but I held off after seeing the Lily's, I'll add it back on again :)
Worth noting, it is only IP44 -- mine was always intended to tuck beneath the guttering here so not an issue. One to bear in mind!
