- 2 Jan 2012
- UK.
maybe mobo limitations
Depends on what motherboard you have?Would that be something that couldn't be adjusted? I could learn to live with that. Only concerned if it's an setup issue and there's lost performance if that makes sense.
Current/EDP Limit Throttling
There can be multiple reasons why the current/EDP throttling is set on the processor. Three common reasons are listed below:-
- Processor Core IccMax is set too low in the Intel® XTU.
- VR (voltage regulator) current limit is set too low in BIOS. Different motherboard OEMs may have different names for this control. Contact your motherboard vendor.
- The motherboard is not able to provide high enough current for the given processor. Pairing a low-power motherboard with a very high Thermal Design Power (TDP) chip can cause current/EDP throttling, even with current limits set to the maximum.
May just be a BIOS setting to raise the VRM Current Limit
Current /EDP Limit Throttling and Power Limit Throttling Indicators...
Explains meaning and settings for Current/EDP (Electrical Design Point) Limit Throttling and the Power Limit Throttling indicators in the Intel® Extreme Tuning Utilitywww.intel.com
Likely the VRM just isn't up to the job of delivering enough power and so the BIOS is limited to protect it.
Unfortunately nothing will work round that - either live with it or replace the motherboard![]()
Well, OP could just point a large fan at the VRMs.Likely the VRM just isn't up to the job of delivering enough power and so the BIOS is limited to protect it.
Point a large 14cm fan at your VRMs and see if that helps.
Pointing a fan at it isn't going to help if the OEM has limited the "VR (voltage regulator) current limit" in the BIOS as per the Intel article.Well, OP could just point a large fan at the VRMs.
That would probably be good enough to improve the performance, especially if it’s a large fan that pushes enough air.
Yeah maybe but a fan is worth a shout.Pointing a fan at it isn't going to help if the OEM has limited the "VR (voltage regulator) current limit" in the BIOS as per the Intel article.
Not sure why people are focusing on VRM temperatures? Surely the OPs XTU Screenshot would say "Motherboard VR Thermal" rather than "Current/EDP Limit".
Current/EDP Limit suggest it's hit a preset limit rather than a physical limit e.g. temperature
The multi core score is not that bad.
What I'd do is sell the i7 and buy an i5 14600K - the K cpus are better binned and consume less power, so probably will give a little bit higher single and multi core performance.
I thought this PC, Acer Nitro N50-640 - b660 mobo would be limited to 12th gen?
