i7 12700f multi-core is under performing
2 Jan 2012
UK.
Hey guys, just installed an i7 12700f into an n50 - 640 Acer pre build system. The single core performance seems great but multicore is down quite a bit from where it should be. Could this be a hardware power limitation? Or could there be something else happening?
Temps never go past around 50c.
Would that be something that couldn't be adjusted? I could learn to live with that. Only concerned if it's an setup issue and there's lost performance if that makes sense.
Depends on what motherboard you have?
May just be a BIOS setting to raise the VRM Current Limit
Current/EDP Limit Throttling
There can be multiple reasons why the current/EDP throttling is set on the processor. Three common reasons are listed below:-
  • Processor Core IccMax is set too low in the Intel® XTU.
  • VR (voltage regulator) current limit is set too low in BIOS. Different motherboard OEMs may have different names for this control. Contact your motherboard vendor.
  • The motherboard is not able to provide high enough current for the given processor. Pairing a low-power motherboard with a very high Thermal Design Power (TDP) chip can cause current/EDP throttling, even with current limits set to the maximum.
Thanks, yeah the mobo is really limited in BIOS options. It's one of those Acer pre build PCs, think the mobo is a cutom b660, the only options I can see in BIOS are basics boot order, turn of VMD etc. nothing that would unlock more juice from what I can see. Maybe it's aggressive on keeping the power use low?
Single core seems fine, just that multi-core performance is down.
Likely the VRM just isn't up to the job of delivering enough power and so the BIOS is limited to protect it.
Unfortunately nothing will work round that - either live with it or replace the motherboard :(
That makes sense, yeah I was worried it was some kind of config issue, so was trying to correct it. If it's a hardware limitation I will just have to make do lol.
The multi core score is not that bad.
What I'd do is sell the i7 and buy an i5 14600K - the K cpus are better binned and consume less power, so probably will give a little bit higher single and multi core performance.
Well, OP could just point a large fan at the VRMs.
That would probably be good enough to improve the performance, especially if it’s a large fan that pushes enough air.
Buildzoid regularly states that even a poor VRM or set of RAM sticks running too hot can be cooled with enough airflow.
I’ll admit, it’s not a pretty solution, especially if you need to use zip ties but if you don’t mind the looks, it will save having to buy a whole new motherboard.
@OP it’s usually the situation with prebuild systems from OEM manufacturers that they skimp on the VRMs and other features to save money.
They might run a different motherboard for the i7 based prebuild that they sell because they know it’ll throttle otherwise.
My aunts partner bought a Dell prebuild with a 9700K and the motherboard came with very few VRMs and no heating on them.
Sheer Madness when you’re spending more than you would for a regular computer from OC.
Point a large 14cm fan at your VRMs and see if that helps.
I doubt you’ll have a side panel to be able to see the fan so just cable tie the fan into position and it’ll be fine.
It’ll stop the VRMs from overheating and possibly extend their lifespan if they are running very very hot as is.
Edit: like this
Pointing a fan at it isn't going to help if the OEM has limited the "VR (voltage regulator) current limit" in the BIOS as per the Intel article.
Yeah maybe but a fan is worth a shout.
If it still throttles even after the fan is installed then it very well may be the a VR limit.
This is why you can’t have nice things with OEMs sometimes
No read out for your vrm temps in hwinfo?
I would take a look at that before taking this step to confirm it.
Not sure why people are focusing on VRM temperatures? Surely the OPs XTU Screenshot would say "Motherboard VR Thermal" rather than "Current/EDP Limit".
Current/EDP Limit suggest it's hit a preset limit rather than a physical limit e.g. temperature
Yes I think your right, all the temps etc are actually incredibly low. Impressive really for such a small PC with an Thermalright Assassin. Like you mentioned I believe it throttles even when temps are ok, based on power consumption or voltage. PC only has a 500w PSU.
The PC performs great, that multi-core score had me a lil worried that maybe something was wrong, but single core is great. Played some Alan Wake 2 on this machine yesterday, performance was great. I think I will just live with the power limitation, if it keeps consumption low maybe not a bad thing.
I thought this PC, Acer Nitro N50-640 - b660 mobo would be limited to 12th gen?
