HDMI
1 Feb 2023
Stoke on Trent
ok I did a search and didn't find anything ... ok my LG LED LQ6300 32" FHD Smart TV as only two HDMI ports/sockets
I would like to have my devices plugged in all the time I have three devices which are blue-ray player / Amazon fire stick / and a hisense HS214 soundbar ...
so I have to unplug one of them? so my question/help is there anyway that I can have them all plugged in please hope I am making sense thank you
One option would be to use an optical cable from the TV to soundbar to free up the HDMI port. The other option is to use a HDMI switch for the Firestick & BD player.
Thank you very much for your reply so would I get a good sound out of the TV/Soundbar using optical cable
Optical sound quality is just the same as HDMI ARC except it can't do the Atmos version of Dolby Digital. If your TV doesn't pass Atmos, or your sound bar doesn't take it, then there's no loss of features.
One important consideration though is how you control the sound level of the bar. If you use your TV remote, or Fire TV stick remote, then those Vol+ / Vol- / Mute signals are getting from the TV to the sound bar via the ARC connection. Optical can't do that. If you change to optical then the sound bar won't wake up or shut down with the TV, and you'll need to use the sound bar remote for volume all the time.
An alternative to Optical is to use a HDMI switch as a way of making one HDMI socket serve two, three or four connected devices. Switches cn be controlled by a pushbutton on the device (you get out of your chair and walk over to make the change), or via infrared remote, or via signal sensing. This last one sounds ideal, but the results can be inconsistent.
Signal sensing does what it says on the tin. When a device gets powered on then the switch senses the video signal and switches to the 'live' input. The fly in the ointment is that some devices never really switch off, or they wake up for a software update or some housekeeping routine that would normally be done in the background, but the switch misinterprets that as a cue to change the input. Sky receivers were notorious for holding auto-switches hostage. LOL :cry:
There are a couple of other things you should be aware of before you hit the buy button.
Splitters and switchers are not the same thing. Some devices sold are indeed bi-directional. They can be used as you want, but also as a splitter to send one source signal (say a console) to two or more TVs. Others are not what the advertiser suggests. Sellers quickly realised that shoppers hadn't much of a clue about signals being directional, or the difference between splitting and switching, and so they were asking for switchers when they meant splitters and vice versa. The response was simple. Just include both descriptions in the ad text even if it's not correct. Caveat emptor.
The second thing is to make sure you buy the right standard. There is stuff still around that just does 1080p HD and won't pass 4K. This is mostly the cheapest gear. That's okay for your Blu-ray player if it's a straight 1080p machine, but no good if you have 4K BD discs or you play 4K streaming content. There's stuff that will pass 4K resolution, but won't do HDR. Some sellers will refer to '4K 3840x2160@30Hz and 3D'. Tread carefully here if you watch Prime / Disney+ / Netflix Premium and the UHD HDR content from iPlayer. If the specs say it's HDCP 1.4 then that's not HDR10 / HDR10+ / Dolby Vision compatible. The same goes for HDMI standard 1.4 / 1.4b or lower.
To play HDR content the switch needs to be up to HDMI 2.0 and this should also make it HDCP2.2 standard.
wow thank you very much for your reply and time in writing it. I really do appreciate it.
would this switch work
HDMI Splitter, HDMI Switch 4K@60Hz, Aluminum Bi-directional HDMI Splitter 1 in 2 Out/2 in 1 Out, HDMI2.0 Switcher Support 4K 3D 1080P, HDCP 2.2, HDR,UHD for Xbox,PS4/5,Blu-ray,TV,Fire Stick,
Just check of your soundboard supports optical. I found a picture of it but could tell whether there's a 'flap' for the optical port or if it's just a trick of the light.
Ignore me, it does.
If you want 4K with HDR, then yes, this looks like it'll work. Just bear in mind though it's based on the seller's description, so they have to have got those bits right. If you buy from the South American River Company ;) then returns are easy.
Side note: first time I've come across a splitter that isn't a splitter; 'can't have two displays on at the same time'. :cry:
was going to put up picture but do know how to do it on here?
and am right that I am not allowed to put a link to the website were I saw it
thank you
I am very sorry if this is a stupid questior or you don't understand what I am trying to say but I will have go. my tv as only 2 hdmi sockets which i use for blue ray player and firestick so to ues my soundbar I have at to connect it optical cable and it is rubbish using it that way ie can't even use my tv remote to change volume anyway I have been told by technical support from both the soundbar and the LG TV that they don't recommend you using a 2 in 1 out hdmi switch so my question is can I connect my blu-ray player via USB port on my TV using an adaptor of sorts thank you for reading my post
I understand what you're asking.
Let's deal with the USB thing first. That's a non-starter. The USB connection on most TVs is looking to play files rather than deal with some continuous USB signal. You should forget about that.
Now let's have a think about your HDMI connections. The reason why tech support don't want you to use a HDMI switch is mostly because the basic ones draw their operating power from the TV's HDMI socket. There is power in a HDMI socket. It's 5V, and it is there to power the sender/receiver chip in the external devices you might connect so that the TV can do its security and standards handshake. The power was never meant to run external peripheral devices such as splitters or switches. That's their main concern. You won't damage anything, but their worry is that you'll be back on to tech support bending their ear if the signal is breaking up or the results are inconsistent.
The solution to this is to find a switch which either takes its power from the TV USB sockets, or get a switch with a wall wart power supply of its own.
Looking at your connections, I think the ARC HDMI is on the back face of the TV. The side/edge connector is just a regular HDMI socket. Your sound bar then needs to connect to the rear (ARC) socket. That will stay connected permanently. You won't be switching or unplugging this. Whichever two- or three-way HDMI switch you get will plug into the edge HDMI. You might decide to use a couple of sticky pads to fix the switch in place and so take the weight off the HDMI socket.
No you can't use the USB port to connect a bluray player or a firestick or anything that sends video to the TV. Video has to come in on the HDMI ports.
You have 2 options:
1: Use the sound bar connected with the optical cable only. You would still get high quality sound, but you would have to control it using the soundbar remote and you may be more likely to get lip sync issues with the audio.
or
2: You use the soundbar via HDMI (ideally use the arc HDMI port on your TV if it has one), and then use a HDMI switch plugged into the other HDMI port, which would have the bluray player and firestick plugged into that. You would then have to physically press the button on it to switch between bluray player or firestick, or buy a model with a remote control and use that remote to switch.
In either case you are going to have to use an additional remote. I can understand you liking how the soundbar intergrates with the TV and makes it easier to use for volume totally. So I would do option 2 and buy a HDMI switch that has a remote. Then you only have to press the remote once to switch.
thank you
OCUK would prefer it if we didn't link to their competition in the market. That's fair enough. They're paying to host this forurm.
Images - I think a lot of us use image hosting sites. That's a bit like a private online photo gallery. We copy the image, upload it to the gallery, and then post a link to it using the Insert Image (ctrl +P) feature. Here's an example of that.
You have 2 options:
or
That's fantastic. I will go for option 2 and I really do appreciate your time and help. It's just deciding which hdmi switch to go for I have no idea which one there are so many so I don't know which one to buy I'm not so bothered about a remote one I have got to many as it is. do you have any recommendations please thank you
Go to a famous website. Search for "hdmi 2 switch". Any of the first 5 results will work. Generally if you can see device in the image with 2 hdmi leads going in and 1 coming out, and that it has a button with an LED next to it (to indicate which is the live input) then it should work. Maybe get a 4K compatible one since they aren't much more.
EDIT: Should be under a tenner
ok I think I know what website I will have a look thank you
