Hey all, sorry this is a big long winded.
As the title says. Recently (in the last week) I have been getting seemingly random black screen crashes. This has happened mid-game, with mild desktop use and at idle. There seems to be no obvious reason for it.
I hadn't had any of these crashes with I was running my 2070 Super OC, but in the last month upgraded to the 4080 and a Thermaltake GF 1350watt PSU. But even so, it had been fine for a good few weeks.
The crashes result in the following:
- Black screen (monitor loses sync) and everthing freezes including iCue lightning effects - Have to force shutdown
- Black screen (monitor loses sync) and everthing freezes including iCue lightning effects and fans ramp to 100% - Have to force shutdown
- Black screen (monitor loses sync). Sound plays in the background. iCue lightning effects keep running - Have to force shutdown
- Black screen (monitor loses sync). This happened once during normal shutdown. Had to force it to shut down.
I had some iCue errors in Event Viewer, but updating iCue cleared those.
I have reseated the video card and power cable (Running on single 600watt rail)
I have run 'sfc /scannow' which found some errors but fixed them, and they haven't shown up since.
I have run a bunch of health check commands through PowerShell and they found no issues.
I have reinstalled current drivers (546.01) - Haven't tried a previous set yet.
I made sure Windows10 is up to date.
This setup had been running absolutely fine for about 2 weeks, it all started going pear-shaped after installing MW3 and the relevant updates for that, but I'm not 100% sure that's the cause.
Event Viewer shows the following errors that seem to lead up to the crash:
Error: "The description for Event ID 0 from source nvlddmkm cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer." There's a buttload of these, but they don't always show up pre-crash.
Error: "The server Windows.Gaming.GameBar.PresenceServer.Internal.PresenceWriter did not register with DCOM within the required timeout." Usually get a few of these
Warning: "The application-specific permission settings do not grant Local Activation permission for the COM Server application with CLSID {2593F8B9-4EAF-457C-B68A-50F6B8EA6B54} and APPID {15C20B67-12E7-4BB6-92BB-7AFF07997402}" Usually heaps of these
And there's been a couple of random others that didn't seem relevant.
CPU and GPU temps are fine.
I'm at a loss.
I'm at a loss.
Granted I missed that the previous card was a 2070 but don't think the other questions were answered in the original post.
