Permabanned
- 10 Nov 2005
Hi,
The main rig in my sig is used purely for gaming under the TV, so that's all new everything, so is fine. The 2nd build, a budget 2nd hand Ryzentosh hackintosh I've built, is now the machine I use for non gaming activity.
Anyway TLDR, it came with a Fractal 450w SFF non modular psu, that works fine, but now that it's become the dedicated mac I use for everything, I want to put a brand new 10 year warranty PSU into it whilst I have some spare money/have an itch to buy something haha
Current spec is a 3600 non X, 2666mhz random 16GB 2x8gb, MSI B450i Gaming Plus AC MITX, Gigabyte RX570 8GB, BeQuiet PureWings 2 120mm chassis and 92mm heatsink fan, and 1x sata SSD - always will be this as I will be getting a 8TB Samsung QVO soon anyway and am not paying NVME 8TB prices!
So not a mega power hungry build but I am on the limit/pushing my luck a bit with a 450w for my GPU already, although it's not gamed on, nor do I really do anything exciting on it bar odd crop of a picture/video... So the real world draw of the gpu is minimal, bit of video playback/streaming, that's about it!
In the future my 5700X/32GB ram will go into it when/IF I bother to chuck a X3D/64-128GB ram in the main rig, and probably treat it to my mates RX 7600 that he's already offered me for cheap in the future - as I know this will work fine with a Hackintosh
and means it's newer than a 6700/6800, so will last longer piece of mind wise for component lifespan of capacitors etc etc, so yeah no real power house... It'll only ever run an AMD GPU due to the lack of modern Nvidia macOS driver support, and I like the vanilla support experience/at worst a cheeky modified kext.
I'd like a 10 year warranty like my full size NZXT C850 Seasonic in a pretty dress has...
I don't want to spend silly money, £140-150 ideally...
So yeah, ao far I've found the following elsewhere, which do you think is best out of these? And is there anything better, from OCUK?
Moving to the interior, integration is about as clean as it can be with this design in such a small space and the topology is modern once more. The component selection features Nichicon standard electrolytics and FPCAP solid electrolytics. There is also an FDB fan from Hong Hua used to cool this unit. Lastly, the documentation with this unit is very basic but the 10-year warranty is an excellent length.
When we look at the Transient Load Tests results for the Cooler Master V850 SFX GOLD WHITE, we see that the results are good but a bit surprising. When directly loaded, the 12v rail showed a peak change of ~340mV, and the 5v rail had a peak change of ~50mV. During the 12v load, the unloaded 5v rail saw a peak change of ~45mV. In absolute terms, these results are in the specification. The surprising part, mentioned above, comes from the fact that at 200W greater in capacity this unit did WORSE than the v650 SFX GOLD which is based on the same platform. This is a bit odd given this is not as hard a test on this unit as it was on the 650W model.
When testing this unit, it was rather quiet overall given all of the caveats surrounding this unit. That said, the V850 SFX GOLD WHITE did become apparent in our load testing environment starting at the 75% load level just like its smaller brother. From that point on, the noise it produced continued to increase. So, this unit seems to be a good option for folks looking for a quiet product offering in this market segment.
Corsair SF850L 850 Watt Fully Modular 80+ Gold
The reviews and OCUK state 7 year warranty but I'm seeing 10 year by another supplier (I WILL ring and check) - IF it's not 10 year I'll definitely not buy it vs a 10 year product of the same price/cheaper like the CoolerMaster! Also the noise is something that would again put me right off vs one that isn't, obviously
Who makes the CoolerMaster? As I doubt it's themselves is it? As with my NZXT being a Seasonic? FWIW I can get that Coolermaster for £139.99 next day delivered and it's RRP is £159.99... The Corsair is £149.99 next day delivered but that's RRP, and I'm definitely not game for buying extension cables!
But yeah, is there anything better on OCUK you guys can recommend, or should I pull the triger and get the CoolerMaster, as I'm looking to buy today
Peace of mind and all that
and means it's newer than a 6700/6800, so will last longer piece of mind wise for component lifespan of capacitors etc etc, so yeah no real power house... It'll only ever run an AMD GPU due to the lack of modern Nvidia macOS driver support, and I like the vanilla support experience/at worst a cheeky modified kext.I'd like a 10 year warranty like my full size NZXT C850 Seasonic in a pretty dress has...
CoolerMaster V850 SFX Gold 850 Watt Fully Modular 80+ Gold
Build Quality
Today’s Cooler Master V850 SFX GOLD WHITE starts things off with a build quality that is very good/excellent for its market position. The exterior represents a well-branded and labeled approach that looks like what we have seen from many better-known OEMs previously. Most apparent in this effort is, well, the color. Whereas the V650 SFX GOLD we saw was flat black, this unit is a stunning all-white with black branding. Everything that was well done with the previous V650 SFX GOLD on the exterior carries over today with simply the color swap in place.Moving to the interior, integration is about as clean as it can be with this design in such a small space and the topology is modern once more. The component selection features Nichicon standard electrolytics and FPCAP solid electrolytics. There is also an FDB fan from Hong Hua used to cool this unit. Lastly, the documentation with this unit is very basic but the 10-year warranty is an excellent length.
Load Testing
Today’s Cooler Master V850 SFX GOLD WHITE started off testing in very good shape. We saw voltage regulation of up to 0.2v on the 12v rail, 0.07v on the 5v rail, and 0.05v on the 3.3v rail. These numbers would be good for any unit. However, this unit is an SFX-sized unit and it is showing numbers that are very comparable to its 200W smaller sibling. This is the first SFX-sized 850W unit we have seen, however, so it makes comparing to other units beyond its sibling a bit difficult. That said, offering these values in this form factor is definitely getting a bit of a bump to this unit’s testing record today. Moving on, we saw efficiency values that ranged from 87.07% to 90.12% efficient at 120v AC input and 85.22% to 89.19% at 100v AC input.When we look at the Transient Load Tests results for the Cooler Master V850 SFX GOLD WHITE, we see that the results are good but a bit surprising. When directly loaded, the 12v rail showed a peak change of ~340mV, and the 5v rail had a peak change of ~50mV. During the 12v load, the unloaded 5v rail saw a peak change of ~45mV. In absolute terms, these results are in the specification. The surprising part, mentioned above, comes from the fact that at 200W greater in capacity this unit did WORSE than the v650 SFX GOLD which is based on the same platform. This is a bit odd given this is not as hard a test on this unit as it was on the 650W model.
DC Output Quality
The DC Output Quality results for the Cooler Master V850 SFX GOLD WHITE were excellent. Overall, we saw peak ripple/noise values of just ~25mV of ripple/noise on the 12v rail, ~15mV on the 5v rail, and ~10mV on the 3.3v rail during our regular load tests. These values are well within specification limits and that means, at a minimum, good in absolute terms. In relative terms, these results are going to be excellent given they are mixed with the V650 SFX GOLD while covering an additional 200W in capacity! This is a nice bounce back from the Transient Load Test results and a bit surprising given those results.Noise
Today’s Cooler Master V850 SFX GOLD is a larger capacity unit than the last power supply we saw from Cooler Master but it is trapped in the same SFX form factor. With that being the case, even though this unit has a large overhead fan and very good efficiency, it is constrained in a number of ways that make noise output more of an issue. One final good point for this unit is that it does feature a hybrid fan controller which means that it is going to be running fanless up to ~15% load (advertised). Of note, while ~15% is advertised our sample did not turn the fan on during our 25% load tests so it was silent to that point.When testing this unit, it was rather quiet overall given all of the caveats surrounding this unit. That said, the V850 SFX GOLD WHITE did become apparent in our load testing environment starting at the 75% load level just like its smaller brother. From that point on, the noise it produced continued to increase. So, this unit seems to be a good option for folks looking for a quiet product offering in this market segment.
Final Points
The V850 GOLD is a very good mainstream 850W power supply no matter its form factor, and today that form factor is very small. From a Build Quality that looks stunning, to voltage regulation and DC Output Quality results that are very good/excellent, this unit was hitting on all cylinders early on in testing as expected from this platform. Then, we had a bit of a head-scratcher when it came to the Transient Load Test results. They were passing but not as good as we had expected. Otherwise, we have very little to quibble about with this unit today.Pros:
- Top performance
- Top build quality
- Good price
- ATX v3.0 and PCIe 5.0 ready
- Top transient response
- Properly configured OCP at 12V and OPP
- Efficient
- Highly efficient 5VSB rail
- Tight load regulation
- Goold ripple suppression
- Long hold-up time
- Accurate power ok signal
- Low vampire power
- Alternative Low Power Mode (ALPM) compatible
- Fully modular
- Enough connectors, including a 12VHPWR (600W)
- Fluid dynamic bearing fan
- SFX-to-ATX adapter bracket provided
- Seven-year warranty
- Noisy at above moderate and at high loads
- High OCP triggering points on the minor rails
- PF readings could be higher
So far I'm leaning on the CoolerMaster as it's normally more expensive and the Corsair apparently has too short of a motherboard cable even in a MITX case according a review I've seen, which knowing my luck will happen to me and not others... And the reports of the Corsair being noisy is a big no no, as is the 7 year warranty older reviews claim - I want a 10 year, as others offer it, so I won't be settling for less.Who makes the CoolerMaster? As I doubt it's themselves is it? As with my NZXT being a Seasonic? FWIW I can get that Coolermaster for £139.99 next day delivered and it's RRP is £159.99... The Corsair is £149.99 next day delivered but that's RRP, and I'm definitely not game for buying extension cables!
