LWB Big Rear Space - £50K ish (or ideally less)
If you are owning and replacing can you stump up the capital to go totally outrageous? Bentley, RR, Porsche etc...
Like whats the depreciation on a urus or something really silly?
I did find myself looking at flying spurs but i don’t want to spend that much. it’s not going to get massive use and 50k is my max budget.
Of the previous generations, the D5 A8 is definitely the way to go imo. 7 series is too similar to a 5 series and the s class falls apart
Is a Panamera worth a look, or are they too old for your budget?
Was going to say before your edit - would be surprised if a Panamera which was reasonably new was within budget. 2016 isn't too bad I guess.
  • Like
Reactions: mjt
Hadn't really thought about the Panamera but it's a good shout. It's decent all round room for 4 that is important, so has to be bigger than a 5 series which sufficed but was a touch tight with 4 up for 3 days of road travel when built like my mates.
Newer ones with the smaller engine are available but surely they're not in the same league as an S class when it comes to rear leg room and comfort?
V6 hybrid Shooting Brake is possible. Obviously not a V8, but 460bhp isn't bad..
