Replaced two taps. Why is everything always harder than planned! Main stop **** to house still lets a tiny bit of water through when shut off. Not ideal. Old isolation valves seized. None on the other tap at all. The isolation valves it does have, are put in really close to a bend, which is really close to the wall. Joy.
Anyway, drained the system down and got to work. Did a bit of a sin...reused the old olive and compression nut on the back of the old seized isolation valve but it seemed in good order. Whacked some jointing compound on and got it installed. I used the ones which terminate in a flat face on the other end for tap tails. Seem ok but I'm going to open and close them every few months to keep them working ok, so that when this Screwfix tap fails again in 2 years with its 10 year warranty, I can whack a new one in in 5 minutes, like the bathroom one I just did the other day.
The handle broke off this downstairs one the other day during my demonstration to the Mrs that the handle was stiff and she was just doing it wrong.
:O
Flow rate was super high so I just toned it down with the isolation valves as this replacement tap does not have flow restrictors in the pack. All seems ok.
So one down one to go. Ensuite tap has been stiff since we moved in and needed replacing too. This time I used some overkill pegler full bore isolation valves with the great big handles, just because I have the room and liked the idea of them lasting longer and never having to worry again. I had more pipe showing this time so cut the old pipe back to remove the old fittings and then used tap tail adapters in the other end for the tap tails. This time flow restrictors were in the box so I used them and meant flow rate was fine. We have a good high pressure unvented system.
But look what nublet here left behind......
Yeah, the old compression nut just chillin there behind the new isolation valve. **** **** !
