- 4 Aug 2007
- Wilds of suffolk
I am on 65%, going to force charge for 30 minutes from 17->17:29 just to make sure I have enough, will loose some in conversion but will be used up after 7pm anyway
That was moi, I also should net at least £12 which should cover nearly 5 days worth of electricity, maybe a week if it keeps dropping to 14p on agile.Oh btw that saving session calculator someone linked above already will tell you todays baseline!
I am starting at 1.18kwh for the session, plus my net export, so should be good for almost 6kwh total I think.
Doubt I will make £15, but should be in for at least £10
My baseline is 0.48kwh.Oh btw that saving session calculator someone linked above already will tell you todays baseline!
This is my first year.
Does anyone remember what last year's dates were? Is it similar?
Solis inverter with pylontech batteries. Not sure if the Solis has the ability to pause discharge without setting the charging rate to 0. Much less of a faff to nip into the garage and turn the batteries and inverter off TBH than playing about with the rubbish app or menus on the inverter.What battery system do you have, do you not have an option to pause discharge between certain times?
ah, thats a bummer, shame you can't connect em to a smart plug heheSolis inverter with pylontech batteries. Not sure if the Solis has the ability to pause discharge without setting the charging rate to 0. Much less of a faff to nip into the garage and turn the batteries and inverter off TBH than playing about with the rubbish app or menus on the inverter.
so that's 6.38 kWh at £2.25 = £14.35, but obviously that's going to be eroded a little by some grid import tonight.
i only made 35p for both the last two sessions as my base usage of 0.140kwhs is so low.......and i dont have batteries to export stored solar.Says I made £0.83 yesterday. Well that was worth sitting on the dark.
Don't think I'll bother anymore.
