Thank you very much, i overthink it a lot but everyone helped so i hope i'll do the best choice!!You won't have any problems at all.
exactly, the settings are plenty so everyone can adjust them to their preferencesFrom the charts posted the differences are a lot more than 10%. You wont have any problen doing the things you want to do with the 6700xt. Finding the right setting is exactly the same running nvidia as it is with amd. Both will work with settings the software chooses for you. But you will get better performance with both nvidia and AMD if you change a setting or 2.
depends on res and game. it will be fine at 1080 for many years yet.Yea and 8gb VRAM in 2023![]()
