I've spent the last couple of weeks killing my thumbs and deminishing my stock of tyre levers trying to mount Vittoria Rubino Tubeless 28mm tyres on my Zipp 30 Course rims...
Ended up this tyre (not used Vittoria before) as Specialized with my usual favourite 'Roubaix Pro 2bliss' winter cheap tubeless are very scarce in the UK. Seems Specialized really reduced inventory & distribution across the whole of Europe too. So I hunted for a well regarded, tough and cheap option to replace them with... Really not convinced this has saved me any money... Yet!
I knew these rims where tight but these where another level of awkward and with the cold weather (& my stubbonness) meant I didn't give up when I probably should've. You know the blue Park Tool levers? The really good almost indestructible TL ones? Destroyed/snapped 5 of them and at least a dozen others (my entire stock of 'crappy' ones). 4 days and probably 9 hours to get a single tyre mounted (good example how stubborn I am)... Including using a tyre mount tool. I figured the cold weather and just getting the tyre on (including heating them up indoors and next to the fire) would stretch them with tubes for a few weeks and they'd be happy mounting again afterwards... How wrong was I!
Gave up, as realised finally after getting the first tyre on, I had buckled the wheel. Pretty badly too! Including bending the rim edge, with it folding inwards from the pressures needed to get it on! Wow. Speaking around some cycling friends (RL group & online) most hadn't heard of that happening before... At least not on a modern rim! Actually used a broken carbon rim I have to see if they would mount well on a different rim... To being able to almost mount it by hand! So really just a Zipp 30 Course issue. Dug out an old pair of unused Fulcrum Racing 7's and although not hand mountable, within 15 mins had both tyres mounted.
Rode them a week with tubes, then mounted as tubeless. Couldn't get one to seal very well... Had my first real 'tubeless explosion' indoors and coated the side of the freezer and a bunch of other stuff in the utility! Ooops! Had the same in my garage and then realised that the tyre had a split/cut just above the bead. Must have been from all the abuse trying to mount it! Argh! Have run it with a tube since but feeling flush (before xmas) bought another tyre to replace it with. As it's on the rear I want it tubeless.
Elves actually got a bit hammered by Hambini, but nowhere near as bad as others and really if you watch his review there's quite a lot of good in there - more so than other big brand frames he's torn apart for lack of QC. Worth a view.At the risk of sounding like a pusher of Chinese stuff, have you looked at the Elves frames? I was close before i opted for my Ican.
Second this. RIP & condolences. Riding gives us some good focus and never underestimate the 'wellbeing' you can get just from getting some time away from other things by getting a few rides in. Great for our mental health!
