Graphics card for sons new rig
18 Oct 2002
Fife
My son is currently at uni studying art and design and a lot of the work involves animation.
We are trying to build a PC on a budget that is suitable for uni work too - would the Ray Tracing of the Nvidia cards be any benefit or would he be better saving the money and getting Radeon?
9 Dec 2006
@ManCave
Does this animation Software Support CUDA or OpenGLs
thats what id ask first, CUDA being NVIDIA openGL being Radeon,
RTX MIGHT help but depends if he uses animations with textures on most dont
OP
18 Oct 2002
Fife
The software he is using is AUTODESK MAYA and ADOBE PREMIRE PRO and ADOBE AFTER EFFECTS for 3d modelling and rendering tasks
To date, ray tracing has been mostly switched off in their workload but that may change in next two years at uni
9 Dec 2006
@ManCave
I litterally learned everything from previous benchmarking experience,
Look At gpu benchmarks for Those programs
but i know Adobe are heavy on cuda
With Rendering more RAM better generally. but again Id look up benchmarks Program 16GB VS 32GB
Man of Honour
22 Jun 2006
This channel does tests fairly often and the general conclusion is that 2D work is fine on either nvidia/amd, but 3D work is best on nvidia. Video is fine on either (codec quality aside).
One of the most common cards for gaming/creativity is the 3060 12GB, because of the price and the 12GB memory.
There are some significant uplifts in some apps between RDNA 2 v RDNA 3 and Ampere v Ada, so something to keep in mind if cards are similarly priced.
Thank you for your input. You seem to know a bit about this stuff ( I don't clearly lol). Would 32GB RAM make a big difference or would 16GB be enough?
For this type of work, get 32GB.
13 Sep 2010
