- 13 Mar 2006
I figure this is probably the better subforum to post this in (if it's better in overclocking could a kind mod move it there!)
3dmark CPU spike by Tom ., on Flickr
I have a question I hope someone can give input on - I'm running a 7950x, crudely overclocked atm with +100mhz on boost clock and -10 all core PBO, with a GTX4090 both watercooled. In 3d Mark Time Spy I'll occasionally will get a run with a blip/spike of 6.2-6.6ish GHz CPU frequency usually on the CPU test, but most timespy runs stay at around 5.7-5.8Ghz cpu frequency. Excuse my ignorance, but is this likely due to a very good core that occasionally gets used for the CPU test, or usual occasional 7950x behaviour from the frequency and voltage adjustment? Thanks for any input.
3dmark CPU spike by Tom ., on FlickrI have a question I hope someone can give input on - I'm running a 7950x, crudely overclocked atm with +100mhz on boost clock and -10 all core PBO, with a GTX4090 both watercooled. In 3d Mark Time Spy I'll occasionally will get a run with a blip/spike of 6.2-6.6ish GHz CPU frequency usually on the CPU test, but most timespy runs stay at around 5.7-5.8Ghz cpu frequency. Excuse my ignorance, but is this likely due to a very good core that occasionally gets used for the CPU test, or usual occasional 7950x behaviour from the frequency and voltage adjustment? Thanks for any input.
