- 19 Oct 2010
Day rate down here for electric is 45.67p
Secondly, an inverter size that can charge your battery from pretty much empty to full within the cheap electricity time window
I'm still on Octopus Go for now until the weather improves/days get longer.Have most people swapped on to another tariff now? Not sure whether to move to Tracker for import and Outgoing? for export. Octopus Compare shows that it would have been cheaper over the last few weeks. It might be more expensive to charge the batteries overnight but I guess that would be offset by a cheaper day rate. There’s some usage that the batteries don’t cover as they can’t discharge enough, electric shower etc.
I feel like I should have been sold at least an 8kw inverter and I'm going to look into upgrading. I'm always having to consider the load and trying not to draw more than 5kw when cooking etc.
Just migrated my tariff over to Flux, and integrated my GivEnergy battery with them.
Trying to get my head around how they're balancing generation with battery charging at the moment, seems to favour exporting over battery charging.
For example currently generating about 2kw, 630w going in to the battery, 347w to the house and 1.1kw going out to the grid.
Battery charged to 79%, could have been higher if it wasn't spaffing out 2kw to the grid during off peak export tariff times. Oy.
Something tells me breaking the Flux integration and doing the automation via Home Assistant is going to be more profitable.
