Deleted User 298457
Deleted User 298457
Hi folks,
I have vowed to grab a streamer ASAP - a few issues with the LG C3 in that very large files don't stream well with subtitles (bitrate saturates the connection) and HDR on the Plex native app is a bit ropey.
I have a windows box nearby I could use but the remote experience is just a tad poor.
So I'm thinking the most simple feature rich device that isn't going to leave me stranded in this answer - I can get either for approx 180.
I know the Shield is older but as long as it works that shouldn't matter? I think the Apple experience is probably spot on for what you want in a good TV situation.
I probably won't game on either. Plex is the primary use case and high quality video. I have a Sonos Beam I'll likely never upgrade - maybe a sub or something.
Thanks!
Thanks!
