- 16 Jan 2005
- Wales
You mean the 20% off if you buy via credit? Excludes most Apple devices including all watches.Is the very thing still working?
Ah, thought it had worked for some as aboveYou mean the 20% off if you buy via credit? Excludes most Apple devices including all watches.
It has and a couple of years ago worked for me.Ah, thought it had worked for some as above
Yeah I think a load of people have rinsed the deal and they’ve now added the clause on. Otherwise I might have been tempted myself.Ah, thought it had worked for some as above
Worked for me last month.Ah, thought it had worked for some as above
Has anyone used back market?
Don’t think they do watches?I’ve always been put off for some reason. I’ve used Mozillion a few times and they’ve been good.
What does that mean with trade in?Was looking at this, https://www.backmarket.co.uk/en-gb/...op-green/c7f2efde-b4dd-48ca-9852-09b927f29701
I use timers a lot and alarms (adhd) so thought a more “ local” Siri would be better
What do you want it to do that your 7 doesn't do?I currently have a 7. Got the itch to upgrade but torn between a 9 and an ultra. If I go ultra I might look to pick up a used Ultra 1. Indecision is killing me
