about £150 per month for gas and electric although I think its down to more like £120 some of the figures above seem high! Although my house tends to be fairly cold in areas I'm not using (Tado Zoned valves)
Its a 1940s cavity wall (but no cavity insulation in old walls) building with a modern (2012) back and side return extension which I think are reasonably well insulated but nothing impressive (I've seen gaps in some of the areas of insulation that I can see). I did also put ~300mm insulation in the loft (200mm on top of the old stuff) and an insulated loft hatch.
Regarding standing charges I'd rather have these than wrapping/including the figures in the per unit costs. Just means people that sit with their houses empty would otherwise make a fair saving.
