That looks lovely cable but the cost by the time you’ve added plugsFor my little 2.1 HiFi setup in the office I use Chord ClearwayX speaker cable with their ChordOhmic connectors.
One of the best speaker cables is Kimber Kable, this is a review from Audioholics with measurements. Audioholics also use Kimber Kable on their high end installs, and have said the only reason it's not always used on installs is due to cost.
Kimber Kable 8TC Speaker Cables Review
The Kimber 8TC marks our very first "official" review of a pair of speaker cables on Youtube. In this video, I discuss build quality and how the Kimber cable...www.youtube.com
Suitable Kimber cable would cost more than my main L/R speakers.
ho ho ho
Kimber Kable measures better, I never said it was cheap.
Watch the video I posted from Audioholics, they show measurements. They also explain why it's used on their high end installations.Sure it does
Anyhow you don't need better cable to improve your audio,your priority is getting rid of these £10 homebase mains extensions that are killing your audio. The sad thing is your don't understand by how much as your so closed minded you'll never even experiment with anything better.
Yeah I think I bought it from futureshop. I needed a 4.5m run and a 3m run. Came to about £200.That looks lovely cable but the cost by the time you’ve added plugs![]()
I'm saying they measure better, that is correct.We've gone through this in the past, the main reason Gene uses these cables is to dress up his system, he even states this in the very video you posted:
I saw this and checked what I have been using for years, it's Fisual S-Flex Studio Grade White Speaker Cable 2 x 0.75mm..... for my rears and I think it's 15m or 10m at least....seems fine to me but now I'm thinking it's not!! Monitor audio bronze rears, the fronts I use thicker bi wire stuff...Honestly, for AV set up cables such as from Kabeldirect which can be purchased on rainforest are a reasonable solution. Make sure you buy a decent thickness for long runs. 2.5mm seems like a sweet spot between retaining sound quality and fitting between side skirts etc., if you want to hide the cables.
Seems very thick for under carpet, around skirting boards....But I guess if it can be done then thicker is better......" That's what she said"...2.5 mm is about right
Just buy a cable that is thick enough for you run with decent shielding that would fit under skirt boards, floor etc.
