- 14 Jul 2005
- Birmingham
Hi so after my recent threads exploring my networking options I am definitely going to put in a wired ethernet cable run from the downstairs ISP router to the upstairs office. This will be run around the outside of the house to wall sockets at each end, nice and neat.
In the living room I have the TV connected wirelessly so need a strong wifi connection there. Apparently the TV only has 100mbps LAN not gigabit lan so I'm better off running it wireless than wired is this correct?
In the office upstairs I will have the PC connected via ethernet but if Im going to use the Quest 3 wirelessly I also need a router/access point there.
I am currently with Virgin Media and have a superhub 3 modem/router. Don't have any real issues with it. But within the next 3 months I might switch to City Fibre so whichever ISP I go with will supply a new modem/router.
Am I understanding correctly that if I have an access point upstairs in the office, that this will be wired to my new ethernet port, and then the PC will be wired to the access point?
Then the Quest 3 will connect wirelessly to the access point as well? For this device its wifi 6e capable so I might be better off getting a 6e access point?
Then downstairs I will have another router (either the ISP supplied one or a separate one), configured as a router. Should I wait to see what ISP router I get before buying one for downstairs?
If I buy the upstairs router now, but not the downstairs router, is this a false economy as I might need a new downstairs router as well? In which case I should buy a matching pair mesh system?
Also Ive seen some of the good routers have many antenna - which seems overkill for the upstairs home office area (I wouldn't have a 6 antenna router both upstairs and downstairs would I?)
Would appreciate advice on the timing of all this and the spec of equipment I need in each location.
