- 19 Nov 2021
- Portsmouth
I bet they're no worse than mineOh don’t worry you’ll feel more than adequate when you see the pathetic numbers I do![]()
Yeah, it's a worry so many people are having problems. At least Wahoo have got back in touch and asked for a few photos and asked me to confirm my shipping address. I guess some new bars might be in the post soon at least. In the mean time, I can use ERG at least, so might try and get myself through some SYSTM workouts in the mean time. Tbh, once the TdZ is done, that's what I tend to do anyway. There was a time I wouldn't change gear for months on the indoor bike.That’s a shame. Really sucks when a premium product has issues and all you want to do is use it! Hope it gets sorted soon.
I'm using my PC monitor at the moment, which although it's 49", it's wide and short. There is a TV bracket on the wall, I'm tempted to buy a cheap 42-50" TV for it...Though I went for a rather puny 42" 4K sceen. Kinda jealous of the big 55" one now!
I've turboed on my mobiles for the past few years, didn't take long to adjust to screen size, but I do wonder if all the extra battery charging cycles because of how much Zwift drains Android mobiles is bad in the long run.you're making me feel inadequate playing on my phone![]()
But was it a 'keep the group together' ride? You'll just get pulled along then, surely?
Yes. It's what I do most of the time.While I have gear problems, can you ride in ERG mode and adjust your power on the fly, from your phone?
Yeah, I know that bit, thanks. In the past, I've done SYSTM workouts and had Zwift running simultaneously. But how do I control the ERG power through my phone?You will need to disable power on the sensor page so that Zwift doesn't control the trainer.
what trainer?Yeah, I know that bit, thanks. In the past, I've done SYSTM workouts and had Zwift running simultaneously. But how do I control the ERG power through my phone?
I have the Kickr Bike V1.what trainer?
