- 8 Sep 2006
- uk
And yet another build I could never hope to do.
Loving the look of this!
I prefer it with the mesh panel on the side. Looking forward to see what it looks like with some lights on though.
Been on holiday for 2 weeks and i see you've made some substantial progress! Looks amazing maate, just wow!
Indeed, I'm cooking with gas as they say!
Another day, another mod, this time to sort the air cooling for the case itself and tackle the issue of the power cable for the 4090.
Take two unsuspecting fans...
...and butcher them!
This solves the problem with the fans hitting the 4090's power cable.
It also provides a guide or tunnel for the airflow to be more directed.
Something else I wanted was the fans to be closer to the top of the case so that it would draw from there and not escape too soon out the sides.
To provide a level of filtration I fitted the self-adhesive mesh filters that Phanteks thoughtfully provides with the Evolv Shift XT to the top cover of the case.
Looks good through the top cover too.
Almost finished, well this part anyway!
I thought you was using the fan shroud to create a ducting tunnel but nice mod. Have you looked at the noctua foam mods for ducting? It would help finish and channel airflow abit better to stop recycling internal case air by getting rid of any potential gaps between the top of the case and the fan itself.
Halfords Deionised, the best stuff i've ever used!
10 years with that coolant and never let me down.
i think PC looks great but having miniitx pc with a massive radiator attached kind of defeats the purpose for me
looks good mate. I really like the Mo-Ra3 and how you have tidied the cables
I love the pipe work, is it copper? have you ever had any problems?
I understand. I went through my itx phase and I went back to a bigger PC (o11 dynamic) but I still have media pc i nr200p. There is something about the small form factor that is appealing.I understand what you're saying but for my application it's makes a lot of sense.
By moving the heat and the fan noise from the PC on your desk to another location means you can have a small PC on your desk. You can cram in a lot more demanding hardware in to smaller footprint rather than having a giant monolith of a PC next to you. Sure, you can put your PC on the floor but I like to see my hardware as I appreciate the aesthetics of them. I also position the external radiator on my window sill so that I can exhaust the heat out the room thereby keeping the temperature of the room and the PC down.
