- 21 Sep 2020
I never find its slow but I do find that it struggles to maintain apps i.e. it has to refresh them or reload safari tabs which is annoying. Main issue is battery life. Its currently pretty awful.
I am considering another iPad to replace this because my partners iPad is old, has a cracked screen and is generally on its last legs. She can take the 11" and I will replace it with something newer for work.
I love the pro and would like another but man they are getting expensive. I am also tempted to get one of the models with 16gb RAM but then you are looking at £1400 for a last gen refurb on the 12.9" version. They are getting far too far towards the realms of macbook pros for my liking.
I guess that up to a point a 12.9" iPad Pro is basically a macbook pro sans keyboard.
This is my big issue with them as well, they’re just getting to the stage where they are stupidly expensive for what they are. Add in the (for me) essential magic keyboard you‘re just shy of 2k. I’d have already upgraded as I hate the battery life in the M pros the previous ones were so much better. I gave my mum my older 11 pro 3th gen and that thing still last longer with a similar amount of use.
