MSI Pro X670-P WIFI - or are there any better alternatives for £200-£250?
https://www.overclockers.co.uk/msi-pro-x670-p-wifi-socket-am5-ddr5-atx-motherboard-mb-36s-ms.htmlSpecification:
CPU | AMD Socket AM5 for AMD Ryzen 7000 Series Desktop Processors |
Chipset | AMD X670 |
Memory | 4 x DIMM, Max. 128GB, DDR5 5200MHz |
Onboard Graphics Outputs | 1x HDMI - Support HDMI 2.1 FRL, maximum resolution of 4K 120Hz 1x Display Port - Support DP 1.4, maximum resolution of 4K 60Hz 1x Type-C Display port - Supports DisplayPort 1.4 with HBR3, maximum resolution of 4K 120Hz |
PCI Slots | 3x PCI-E x16 slot Supports x16/x4/x2 1x PCI-E x1 slot PCI_E1 PCIe 4.0 supports up to x16 (From CPU) PCI_E2 PCIe 3.0 supports up to x1 (From Chipset) PCI_E3 PCIe 4.0 supports up to x4 (From CPU) PCI_E4 PCIe 4.0 supports up to x2 (From Chipset) |
Storage | Total supports 4 x M.2 slots and 6 x SATA 6Gb/s ports M.2_1 (From CPU) supports up to PCIe 5.0 x4 , supports 22110/2280 devices M.2_2 (From Chipset) supports up to PCIe 4.0 x4 , supports 2280/2260 devices M.2_3 (From Chipset) supports up to PCIe 4.0 x4 , supports 2280/2260 devices M.2_4 (From Chipset) supports up to PCIe 4.0 x4 , supports 2280/2260 devices |
Networking | 1 x 2.5Gb Ethernet WIFI 6E Bluetooth |
Audio | Realtek® ALC4080 Codec |
Connectivity | DisplayPort 2x USB 3.2 Gen 2 10Gbps (Type-A) 4x USB 3.2 Gen 1 5Gbps (Type-A) 2.5G LAN Audio connectors Flash BIOS Button HDMI USB 3.2 Gen 2 10Gbps (Type-C Display port) USB 3.2 Gen 2x2 20Gbps (Type-C) S/PDIF-OUT |
Internal Ports | 1x Power Connector(ATX_PWR) 2x Power Connector(CPU_PWR) 1x CPU Fan 1x Pump Fan 6x System Fan 2x Front Panel (JFP) 1x Chassis Intrusion (JCI) 1x Front Audio (JAUD) 1x Tuning Controller connector(JDASH) 2x Addressable V2 RGB LED connector (JARGB_V2) 2x RGB LED connector(JRGB) 4x USB 2.0 ports 4x USB 3.2 Gen1 Type A ports 1x USB 3.2 Gen2 Type C ports |
Form Factor | ATX - 304.8mmx243.84mm |
Warranty | Three Year Manufacturer Warranty |
