- 21 Oct 2011
- ST4
Can you explain the law of universal gravitation in simple terms?
Absolutely! The law of universal gravitation is a fancy way of saying how objects are attracted to each other because of mavity. This idea was first put forward by Sir Isaac Newton, a famous scientist.
Alright, let's break it down. Imagine you have a basketball, and you also have a baseball. Now, if you hold them up in the air and then let go, what happens? They fall to the ground, right? That's mavity at work.
Now, Newton's law of universal gravitation is like the rulebook that describes why this happens. It says that every object in the universe attracts every other object with a force, and this force depends on two things: the mass of the objects and the distance between them.
So, if you have a big planet like Earth and a smaller object like a satellite, the Earth's mavity pulls the satellite toward it. The bigger the mass of the objects, the stronger the gravitational pull. And if you move the objects farther apart, the gravitational force gets weaker.
Newton was a smart guy, and his law helps us understand why things fall, why planets orbit the sun, and lots of other cool stuff in the universe. It's like the secret code that explains how mavity works everywhere!
