3070 to 4070S?
5 Nov 2003
Chesterfield
I want a squeeze a little more performance out of my set up, kind of limited by my PSU (650W), but the 4070S does seem to have a low TDP.
I've read it's c30% improvement on performance? Any views?
Yes, many will tell a mere 30% is not worth the outlay. In graphical boost.
However, if you want a quiet GPU (RTX 4070S), that is built on a more modern node, that has more VRAM (12 gigs) that will in theory be better for 1440p. Then, this is a popular choice.
Playing devils advocate, why not consider an AMD 7800XT for £100.00 less with far more VRAM. Just check your PSU can cope with one.
Thanks for the reply will take a look.
Which is the correct answer. ;)
Aside from vfm for the upgrade, there's also that when the improvement isn't that big on average, some games can actually show almost nothing, or worst case they're slower. I don't think that would be the case with a 4070 Super, but it's something I'd think about with lesser upgrades.
You should be getting at least £250 if you sell your 3070, a £500 or £600 upgrade doesn't seem too shabby then.
As an owner of (Seasonic) 650W PSU, I would have no problem putting any current GPU in. Rest of the system is barely 150W max, so even a 7900XTX or 4090 would have room to spare
RTX 30 series top cards had a nasty habit of power spikes going way over power limit, but current cards are fine.
Purchased a 4070FE. Upgraded from 3070FE. Massive performance boost which I wasn't expecting. Running games at 2k the 4070s is hitting the sweet spot :)
Running an RX 7800 XT with a 7 year old EVGA Supernova 650 GS PSU, no issues at all and his Ryzen 7800X3D is more power efficient than my Ryzen 5800X. :)
Am I missing something? There is no way a 4070 super is only 30% faster than a 3070?
It's at least 40% on average, and often much, much more depending on the game and resolution.
https://www.techpowerup.com/review/nvidia-geforce-rtx-4070-super-founders-edition/31.html
It's the difference between 40fps and 60fps, that's massive!
It always depends on the circumstances. If someone is struggling to get playable FPS at 4K (which I assume is what you're referring to with 40 versus 60) then for £600 they might consider it money well spent, but usually from any previous gen card I'd want to move up a tier (especially since nvidia keep moving them down one). If the 40 versus 60 fps @ 4K is our justification for the upgrade, for example, then in a few years this card won't be playable at 4K again, whereas if we move up a tier, then it should last a bit longer.
No, there are plenty of games released in the last two years that get 40-45fps at 1440p with a 3070. Now he can play them at 60+fps, and if due to VRAM limited he could even play at 75-80fps.
Just sold my 3070ti FE and upgraded to a Zotac 4070S triple fan and it was a good upgrade for me. PC is quieter, less heat generated and 100watt less power useage when gaming.
Plus I think right now is the right time to sell the 3 series GPU while it can still get some decent money back, prices will start to come down closer to the release of the 5 series.
4070S is the sweet spot for 1440p gaming right now.
I have been away for a while, but appreciate the response. I am still pondering this but seems like a sensible upgrade.
Thanks.
+42% at 1440P and 4K.
with a half decent one being £620 i don't think its worth it, no, and its 12GB, which is on that minimum line these days, i'd be worried about its longevity.
That was exactly the same conclusion I came to when deciding what to upgrade to from my 3070 that was running out of vram. As you know I switched to team red and went for the newly released (at the time) 7900GRE which was on offer for £529 and I am glad I did as it's a cracking card. I don't miss DLSS as the 7900GRE can max out anything I have played so far at 1440p with sheer grunt alone.
I went from an RTX 2070S to an RX 7800 XT.
My recent buying habits have been GTX 970, GTX 1070, RTX 2070S, notice a pattern there?
People say with 8GB cards you will run out of GPU grunt before VRam, not true, i have serval examples where that is not true and i've recorded a couple if people don't believe me, Rust 120 FPS no problem, until you get anywhere near the Scrapyard, then its 17 because the of VRam overflow.
So i was never going to buy the 3070 and the RX 6700 XT i thought was a bit 'meh' for not much less, its more like a 3060 Ti.
And then the 4070.... this was the longest time i've ever kept a card, i usually buy in the mid range but upgrade every generation, not this time.
The 7800 XT was just what i was looking for at the right money, so i bought it and..... i love it, fantastic GPU, great drivers, its never put a foot wrong, i have kicked my self a little because the 7900GRE came out a couple of weeks after i bought it and i think its a better GPU even for a bit more money, but i'm still very happy with the card, i have no qualms with going AMD again, none what so ever, Nvidia have to convince me at this point, they have to work to win me back.
